new addition to fleet
jgra1
(Donor 2021)
x 37
Re: new addition to fleet
Unread post by jgra1 »
Thanks all.. Jim a star drive of course .. ! :)
Lexi so far I am about 10 hours in but going pretty slowly. I am enjoying it. The farm is quiet in the evenings .. radio is on, occasional 6x cans appear ;) it's just a hobby really. Fingers crossed this weekend is not to wet.. nothing yet.
More details later.. popped home 2 fields away to refill the tea mug.
New engine just arrived on a palate.. Dare not unwrap it in case it's a 2 stroke chainsaw engine or something
Oddest Christmas present I have brought myself !
x 8368
I thought at first you said the engine arrived on a plate John....
I think it's a perfect Christmas present actually John ;)
I'd be happy wiith something like that. Just think of the X7 as a Christmas project. Sure beats being comatose in front of the telly stuffed with turkey and pudding...
lexi
x 134
Unread post by lexi »
Got you John....a bit like myself. Every day a task and some result. Working on stuff is good for you and a days work is a nights sleep.
I built a log burner for garage last year......best thing ever.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8368
lexi wrote:Got you John....a bit like myself. Every day a task and some result. Working on stuff is good for you and a days work is a nights sleep.
I fully agree with that lexi :-D
jgra1
(Donor 2021)
x 37
question later folks.. a few pics from today..
laptop battery is dying and i forgot charger :evil:
x 5671
Nearly done then John?
jgra1
(Donor 2021)
x 37
not quite Steve .. :)- yesterdays pics are all in reverse time order, I forget to say ;)
long story short.. new engine turned up Saturday morning.. old engine was removed soon after.. new unit looks - and is - an exact copy of old.. I set about swapping some bits for the rest of weekend, and the rain held off.. Gearbox refit was tricky this afternoon.. lining up Torque Converter openings with lugs on the input shaft plus all the splines while grabbing 80 KG of box was harder then I remember, even with the crane I still managed at least an hour for this bit.. tipex was useful in showing locations after the engine and box were closing in.
So, a week after buying the car with a hopeful oil pump fail, I have brought another engine, and during evenings after work and 1 weekend I am nearly ready to drop the new unit in.. but it feels a rollercoaster somehow.. I think a lot of us know how to do a 'Haynes job' on every aspect of this refit (and I would love to).. but I have other pressures against me..
So, I neglected to buy and change the rear crank seal.. no obvious signs of leakage and I wanted the box on today...
I haven't changed the cambelt (donor car was 60K allegedly)
I have checked the turbo has no movement..
I have changed the oil filter
but I now have a bit of time.. a small bit.. with the engine still out I can do things to help it, if it starts and runs ok..
Today I detected the turbo on the old engine had gone.. and that engine had excess oil in the pipework..
this donor engine has some oil presence in the pipes, as does my everyday C5 110..
I don't really know if the original engine suffered turbo then oil pump or vice versa..
The turbo oil feed pipe has a long filter on, and I need to read up on the 1.6 engine and issues with that.. if the filter should be cleaned changed or removed I still have time before refit..
the oil in the bellhousing pic is dark, but red.. so I am sure its my tranny fluid and not engine oil...
I cant see the gearbox would come out with the engine in place, but I am not 100% on this
removing the turbo in situ would be painful.. but it always is with a rear mount turbo on an inclined motor.
may have more thoughts tomorrow..
J
wurlycorner
x 271
Unread post by wurlycorner »
Great progress by the sounds (pics aren't showing for me, for some reason?)
:-k I believe I have read on here about the importance of changing/removing the in-line filter in the turbo oil feed line on the 1.6hdi?
If the engine is out, I genuinely can't see a good reason not to change the cambelt. It will never be that easy (or cheap) to do, again!
Iain
CX DTR T2 Safari (silver)
x 8368
wurlycorner wrote:(pics aren't showing for me, for some reason?)
Same here on two different systems and browsers...
I thought it was just me...
Xantidote
x 5
Unread post by Xantidote »
And I thought it was just me :(
Martin
1995 Xantia TDLX (deceased :( )
jgra1
(Donor 2021)
x 37
Ooh. Sorry about the pics chaps.. will have a look about that in a bit.
Yes wurly I'm will do the cambelt..I agree with you..
I will change the oil feed pipe .. remove the filter . Remove and clean out sump
Swap injectors
and I think that's me done..
Read a lot now on the 1.6 problems.
jgra1
(Donor 2021)
x 37
can anyone see the pics in my post (3 posts before this I think)
not much news.. ordered a cambelt, the turbo pipe, seals, injector seals, Tie rod.. - several of these had to come from dealers.. I asked if the oil pump had been uprated and he said no.. a possible chain change only !..
I went at both crank pulleys tonight, wasn't easy getting them off on my own with no starter to help..
both had timing which was set the same and looked spot on..
the original engine has compression! lots.. don't understand.. garage said they had compression checked it and found none...
x 3566
Pictures now visible :-)
Don't forget to have a damn good look at the steering rack pinion to see if it's in any way on the way out. A common failure :-(
jgra1
(Donor 2021)
x 37
thank Bobins.. :) pics are in the right order now
Pinion : I have looked once, I saw a brown rust coloured shaft and I turned away quickly.... no leak yet... may slightly undo and tighten any relevant bolts in that area to help in the future.. will try and take some close up pics of the rack at some point, as working on them is hell when you cant see and don't know what's what
that lower sphere on the right rear of the engine bay looks like a job to change on a normal day !
lexi
x 134
Is the latest Aisin tranny fluid red coloured?
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
