Diesel pump sprocket and timing Question
citroenxm
Fallen Hero
x 70
Re: Diesel pump sprocket and timing Question
Unread post by citroenxm »
Yea.. dont be inclined to go over board incase you rip out a thread or two.. all your weight is far enough really. Never had issues with that before..
A very sad...
1994 XM 2.1 d auto
harryp
(Donor 2022)
x 73
Unread post by harryp »
Thanks for that citroenxm! The bolt was still giving if you know what I mean, and I was using a torque wrench(21in) with a large comfortable grip and longer than my breaker bar(16in). I usually tighten up until the "give" stops!! Didn't want to strip it - but I only weigh 70K - so it still wouldn't be a lot!!! On a different tack. how do I remove the engine fuse box, have removed the rear bolt but something is attached on the n/s inner wing side and I cannot see what! I am trying to remove the positive battery loom which is in a dire condition. Thanks for any info!
Harry
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
citroenxm
Fallen Hero
x 70
Pop out the two purple relays then twist out the relay sockets out the platic holder.. remove the holder and im sure buried down there is a 10mm bolt...
A very sad...
1994 XM 2.1 d auto
harryp
(Donor 2022)
x 73
Boy, that is a speedy reply, thanks so much!! I have 3 green relays, one on the n/s and 2 over on the engine side.......
Regards, Harry
citroenxm
Fallen Hero
x 70
Ok.. if you get the relays out and move the plugs etc out the way you should find the 10mm bolts buried down under all the other wires etc..
A very sad...
1994 XM 2.1 d auto
harryp
(Donor 2022)
x 73
citroenxm, Thankyou. will do first thing. Sun down, gnats out, no garage .....and once again, thankyou
Harry
Regards, Harry
John Plum
x 5
Unread post by John Plum »
citroenxm wrote:#its the Vaccum valve for the Pump Advance when the car is cold. It runs off a Vaccum controled by an Electro valve, rather then the Wax Stat that was perfectly good enough for years.
John, if the car starts perfectly and runs nicely, I wouldn't worry about it for now at all...
Just thought I'd update this bit, because the valve makes a big difference to driving, and you can only limp about with it malfunctioning:
I believe its called the 'LDA manifold pressure compensator' - controls delivery quantity as a function of charge air pressure.
There were a choice of three when I replaced mine, and I had to have the old one ready to match up.
It made all the difference to fuel boost, and hence driving.
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
