Should it stay or should it go?
jonnydrumm1967
Yes! They're actually a lot stronger than the XUD9 I believe,no mean feat! Overall Peter I must agree with you though,if absolute reliability is the key then it has to be the XUD,it's half the reason I'm buying the 405! Fixability,too is so much easier and cheaper. I got the Xantia cheap and I think I've just been lucky!
Cheers, Jon
Cheers, Jon
2000 XANTIA HDi 110 SX Est
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
1992 205 GTI TD
1996 DISCOVERY TDI
2001 XANTIA HDi LX
1991 205 D Turbo
- x 1240
falling-out-with-my-car
- x 25
Only if you change the oil frequently I suspect.
Citroenmad
- x 110
Some 405 estates had hydraulic rear suspension did they not? Was it on the range topping 4x4 or something. I remember we used to look after a 405s spheres a long long time ago.
Peter, im surprised your not interested in 2.1TD Xantia estates as well? Or do they use a different fuel pump to the Xm 2.1 Bosch?
And no i dont remember seeing a very untidy one, i still see some around here, they must be very good cars to stick it out this long. I dont often see many BXs now, or even earlier Xantias.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
- x 25
I was under the impression that was air suspension, ok they had spheres but they also had a valve inside the rear wing that could be connected to an airline and the rear end could be stiffenned to carry heavy loads or for towing, I had an old vauxhal cavalier Mk1 estate that had air suspension and it to had spheres to store the presurised air.
Xaccers
- x 188
alas the 2.1TD Xantias all came with the veg killing Lucas Epic(ly slow)Citroenmad wrote:Some 405 estates had hydraulic rear suspension did they not? Was it on the range topping 4x4 or something. I remember we used to look after a 405s spheres a long long time ago.
Conversion to a 1.9TD bosch pump is apparently possible though.
DIY sphere tool
DIY sphere tool
- x 1240
I think the same applies to all diesels, I change mine every 5k.falling-out-with-my-car wrote:Only if you change the oil frequently I suspect.
Xantia is not big enough, if I'm going to have all the hassle of hydropnumatic suspension I want the maximum benifit from it
- x 25
Peter,
I'm with you there on seats, I have already had to strip one down to the frame and have it welded, because the welds done at the factory were rubbish.
- x 1240
I don't know what the standard VSX seats are made of but they just don't seem to wear out, I sold one at nearly 300,000 miles and the seats were near enough perfect - apart from being big and comfortable. I have a 190,000 black SX hatch and the seats in that literally look new, better even than the VSX.
- x 8365
I've had a couple of 405s. Best Pug (after the 205) ever
In 1.9D or TD form, absolutely 100% reliable and they go on nfor ever and ever. My old 1.9 GRD (NA) used to return a consistent 53mpg
It was the Mi16 4x4 with the hydropneumatic rear end. Mostly all gone now, weak transfer boxes (shared with the BX 4x4) and the attractiveness of the D6B engine for 205 Mi16 conversions saw them off as it did for many BX 16v GTis
Xantia seats, with the very notable exception of Alcantara, lasts almost indefinitely and will take all kinds of abuse and still scrub up well. Leather seems almost indestructable too, save from sharp objects.
Xac, you really do seem to have a problem with the Lucas EPIC
addo
- Sara Watson's Stalker
- x 95
Xaccers
- x 188
You know I'm only teasingCitroJim wrote: Xac, you really do seem to have a problem with the Lucas EPIC![]()
Ok so it doesn't let the car use it's 110BHP in any fun way, but it does give (everyone but me it seems) good fuel economy
When I was growing up, after dad had two 205 XRD's (one which he managed to sort of get away with doing 110mph in because the police couldn't believe a 205 D could go that fast - he was charged with exceeding the national speed limit instead). As my sister and I got older, the 205 was traded in for a 405 GRD estate which was lovely, and frankly the 205 and 405 estate were the last good looking cars Peugeot made (405 saloon is ok with a spoiler but doesn't look as good to me as the estate).
It's one of the reasons I went for a Xantia, to me it's the natural evolution of the 405 style.
DIY sphere tool
DIY sphere tool
- x 1240
There are quite a few 405 estates about down this way, I probably see at least two on a trip of a few miles. The best ones, or at least the ones with the most comfortable seats were the pre '95s. I ran a late one for about a year but had to change the seats, the hard side bolsters gave me a pain in the backside. I changed from an XM to something 'simpler' but soon changed back again, not because the 405 was a bad car but the XM was so much nicer. I could live with a 405 though.
addo
- x 95
Being serious, 405 drivers seem to smile more behind the wheel, than other motorists. Odd, but possibly they really enjoy driving.
(Yes, I do watch peoples' faces and look at the cars they're piloting!)
Between a 405 and a Xantia, I like the low-down torque of the 405, and it's nimbleness. However, I can push the Xantia harder into a corner if neither is desired to oversteer.
- x 1240
