x 7164
Hands up if you took the time to watch Matts follow up video on the unusual Jaguar XK150 Foxbat Estate model I posted up. Only one one-off real car produced but 403 1/43 models in a special edition. In a continuing fine example of picking up the ball and running with it, that video supplies "Lovely Gearsticks No2". Not particularly for its form, more for its unusual movement which you can see in the video. Watch it here viewtopic.php?p=810741#p810741
NewcastleFalcon wrote: 19 Jul 2024, 14:03 Lovely Gearsticks No 1
Lovely Gearsticks No 2 (and a very decent "fly off" handbrake too)
x 8370
Ahh, the good old original Mini gearstick before the remote change came along :) Very direct and straight to the selector forks but the 'give' in the long lever made it a bit less precise than it could have been. It exemplifies the drive to make the original Mini as simple as possible. I think it suits the vehicle rather well, as does the authentically perfect oval instrument binnacle in the middle of the dash; another design simplification to maintain as many common components between the RHD and LHD models. Yet another nod to this philosophy was the push-button starter on early models.
That XK150 Foxbat gearchange looks distinctly kinky and not at all pleasant to use...
x 8088
I'll nominate this for number 3 in the gearstick list: :-D
x 2941
CitroJim wrote: 23 Aug 2024, 08:58 Ahh, the good old original Mini gearstick before the remote change came along :) Very direct and straight to the selector forks but the 'give' in the long lever made it a bit less precise than it could have been. It exemplifies the drive to make the original Mini as simple as possible. I think it suits the vehicle rather well, as does the authentically perfect oval instrument binnacle in the middle of the dash; another design simplification to maintain as many common components between the RHD and LHD models. Yet another nod to this philosophy was the push-button starter on early models.
That caused a few problems at first because mechanics and DIYers instead of using the jacking points jacked them up in the most convenient place and in doing so chopped through the battery cable and destroyed the battery with a full out short circuit.
x 8370
Gibbo2286 wrote: 23 Aug 2024, 09:50.
CitroJim wrote:Yet another nod to this philosophy was the push-button starter on early models.
Gosh! That must have been quite a spectacle to witness when it happened Eric!
x 7164
CitroJim wrote: 23 Aug 2024, 11:52
Couldn't quite work out how that would have happened until I remembered "Battery in the boot" of course, and a cable run somewhere under the car back to front. My 1969 Mini also had Hydrolastic pipes front to back, not a great jacking point either!.
x 2941
Lucas weren't happy when they suddenly had a pile of failed battery guarantee claims. :)
x 3566
Very RED in case you hadn't noticed :lol:
A Maserati Giblet GT coming up on auction.....
https://auctions.wbandsons.com/auction/ ... 2&pn=9&g=1
x 7164
Lovely!
x 7164
The Cue Ball type Gear stick Gallery
New Addition Today
x 7164
7 points for each of these Black Balls
x 2341
Unread post by MattBLancs »
Found by Mick, here: viewtopic.php?p=817980#p817980
But you done get many instrument clusters like this nowadays!
(Argh!, image saved as incompatible webp format, bear with me)
https://www.carandclassic.com/auctions/ ... f3c80747ca
Nope, failed again, resorted to a print screen!
I'd have to sort the wonky clock (that also seems to be a different back colour??)
x 8088
Are you after this Matt?
With ignition switch on the left, click on to enlarge!
BFTW
BFTW
x 2341
mickthemaverick wrote: 20 Oct 2024, 17:28 Are you after this Matt?
Nope, better view with Image 54, hopefully above at last! :-D
x 7164
One more for the Cueball connection
Mercedes Benz 300SL (1954-1957)
