Merged Lexia & Diagbox threads
C5_Jack
Re: Merged Lexia & Diagbox threads
Hi Harry
Who is it?
I need to order one as well! Group buy anyone?
Jack
Who is it?
Jack
- x 6947
Take that with a pinch of salt. Get one from Easydiagnostics here in the uk, with backup and support if you need it . Not the cheapest, but you know what you are getting and won't have to risk an in known supplier.
harryp
- x 73
C5-Jack,
for info see
http://www.ebay.co.uk/itm/REAL-Full-Chi ... 6#shpCntId
Info I gleaned on versions was from easydiagnostics, so think I will go with them. It all stops this year apparently as previously mentioned. Thanks to Marc - and for late versions 'easy' are amongst the cheapest anyway...
for info see
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
- x 6947
Harry - suggest you stick with the updates supplied with Easy - as this will cover your C5 easily and beyond. Patching further can be a minefield! Good luck.
harryp
- x 73
Update...
Easydiagnostics have sold out.
Maybe back to the drawing board...
Regards, Harry
- x 6947
I've just emailed Sharon to see when they're getting more stock. I'll post update ASAP
- x 6947
Harry, have received an email from Easy... They went out of stock this afternoon! They should be receiving new units this Thursday / Friday. They'll email to confirm and then I'll post straight back to advise you.harryp wrote:Update...
Easydiagnostics have sold out.![]()
Sloppysod
- x 397
Hi All, I think I was running version 7.6 (I decided up install the next patch about 3 months ago and not used it since) diagbox without any problems and installed the version 7.65, now I get an error message "connect your measuring card and validate" I have connected it to my car without any luck, still the same message - any idea?
have got to go back to the earlier version or do I have another problem?
Stu
- x 6947
That usually comes up when you have selected the measurement option from the top menu. If you back out of that or cancel with red cross, can you go back to the man menu and choose the global test?
Also. when you applied the update, when it finished did you restart the PC then go into diagbox when it booted up for it to apply the update?
harryp
- x 73
Marc, was in touch with Easydiagnostics and was told they sold the last one just after I had spoken to them
. They too suggested phoning me when stock arrives! Thanks for your attention - appreciated
. Next problem may well be trying to load the software.
On a similar topic - docbackup and Sedre! Loads ok but jumps dvd2. Then when running Sedre, calls for dvd2 and loads from it. Can it not load all 3 dvd's? Understand that Sedre must be uninstalled before updating, but what about docbackup? Can that be installed over the existing version? Want to go from 2012 tp 2013, which I understand is the last and final version before it goes on-line only!
Regards, Harry
- x 6947
Hi Harry, no, both of these like clean installations and the software should be fully removed and the directories that they created too. If not you're likely get some corruption down the line.
When installing Sedre will go on first with installer remaining in the background. A successful installation will ask for all 3 DVDs and will take ages depending on your PC speed, hard drive and optical drive.
Also there are some special instructions about Sedre docbackup co-existing with Diagbox, avoidable if you install Sedre and docbackup first. I actually run Sedre and docbackup on a virtual machine as I use it more on my desktop than the Lexia laptop, so they are separate.
Easy should have some stock back in tomorrow I think Sharon said.
C5_Jack
Hello All
Do we know if Easydiagnostics have it back in stock?
Jack
Jack
harryp
- x 73
Hi Marc, did remove all software and directory's. Think it requires the register altering too, as it does not ask for any install codes but just goes straight in; and goes from disk 1 to disk 3. Annoying.
I am running this on a separate PC running Win 7.
My Lexia is on a laptop running XP Pro SP3, so no conflicts there.
Regards, Harry
- x 6947
Jack - awaiting confirmation today, they'll email me as soon as they are and I'll post back at same time.
C5_Jack
Cheers
Don't want to hassle them for nothing
jack
jack
