Well.......I'm now back to Lexia, works at moment so as they 'if it ain't broke....'.
May play with diagbox on the old laptop at some stage, usual Acer broken hinges, will only run on mains but still fires up enough to give it a go.
Merged Lexia & Diagbox threads
old'uns
- x 127
Re: What is Bashe 5? + Diagbox Info
old'uns
- x 127
i've now given up trying Diagbox....keeps throwing up errors after first activation input...PP2000 i think?
tried all ways of files, discs and the final straw was the continual messages of low space on disk
luckily i don't live in a Flat!! just the simple Lump hammer for it
hirameuser
Bombed interface while reinstall went past midnight pluged lead in after installing 6.01 which worked, but after next up grade and changing true to false can't connect to interface( I did not even have a drink!). So how do I get one of easydiags interfaces to work now? or is it shot. I know its probably already been posted before but not where I've looked, can someone please point me in the right direction or do I need to contact Jim for new firmware.
Phil D
Phil D
Trainman
- (Donor 2018)
- x 43
I finally got round to doing the resolution this morning and tried it on the C6, wonderful, working as it should be....... thanks again Simon.Mandrake wrote:A month late I know but the file is at c:\app\lexia\exe\ecran.ini
largeur_ecran is horizontal resolution, hauteur_ecran is vertical resolution. I too have my vertical resolution set to 600 for a 1024x600 netbook screen! By the way I have run Lexia/Diagbox on a Samsung NC110 and it does a pretty good job as long as you have 2GB of ram. (The one I was using did, but I'm not sure if they all come with that - I was using Windows 7 Professional 32 bit as well)
Steve
http://c6owners.org/index.php
Dave1987
I havw got the Lexia 3 V48 PP2000 and the newest diagbox V7.49, i was told only install the software on xp mode. What's more, I need to install PP2000 and diagbox separately.
xantos
- x 10
Well I'm trying to install Diagbox 7.02 on my laptop, as my friend has Citroen DS5 4x4 hybrid, and the car doesn't start. Previously I had Diagbox 5.xx which was working fine and presumable I have a Chinese clone, but I not sure, as I bought it second hand about a year and half ago. Didn't expect to work but something curious happened...
When I installed Diagbox 7.02 (many thanks Mandrake for your link
), and connected the interface (not connected to any car) this came up:
I'm curious... Trying to diagnose Xantia, no success, but when trying to diagnose DS5 it looked like it works. No dialogue with any of control units (as the car was not connected), but it was trying to make dialogue with no errors...
Is there a way to determine which interface do I have?
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet
C4 Exclusive 2.0 HDi (gear shifting b****!)
Dave1987
Re: Diagbox/Lexia
Thx for the manual.
Here is the video manual
Who has got the diagbox v7.57 download link
xantos
- x 10
Well a bit o research and voila!, my clone interface is now compatible with Diagbox 7.xx.
Anyone who is also interested in doing so, here is how. Contact member nlc (_http://www.tlemcen-electronic.com/forum/showthread.php?t=15953_) and ask him to send you an update for the interface, which you can load through USB (instructions included). It changes the serial number (at least the last letter to /C, which is not blacklisted), so you can use Diagbox above 5.29 with the interface. He asks for a small fee for his work.
I updated the interface yesterday and now it works with Diagbox 7.02, at least on my Xantia, didn't yet try it another car.
Hope someone finds this info useful and saves him a lot of googling
Mandrake
- x 695
That's great news Xantos.
Now that your firmware has been re-flashed to run 7.xx it should run versions right up to the very latest. (I have no idea what that is now, I'm still running 7.02 as it's all I need for my Xantia)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 5674
Re: Merged Lexia & Diagbox threads
Lexia topics merged to try and keep all Lexia info in one place.
xantos
- x 10
Well I can confirm that it works with other cars too. Yesterday I have diagnosed DS5 hybrid 4x4 without problems.xantos wrote: I updated the interface yesterday and now it works with Diagbox 7.02, at least on my Xantia, didn't yet try it another car.
Here is a link where you can download Word file, which contains links for downloading DiagBox 7.xx. Hope Mr. Scarymistake from CarTehnology forum doesn't mind
https://mega.co.nz/#!vxdQWQLR!Ss0zpMli0 ... xgGYNvFe3s" onclick="window.open(this.href);return false;
aneesh84
- x 29
I have a Xantia and running diagbox 7.02. Is there any advantage for me for upgrading to higher versions?
Xantia Estate 1999 2.0 HDI 110
C5 2005 2.0 HDI 138
Nissan Leaf 2018 40Kwh
C5 2005 2.0 HDI 138
Mandrake
- x 695
For a Xantia, none at all.
Simon
1978 CX 2400
1978 CX 2400
Homer
- x 16
Apologies if these have been discussed before, my forum search came up blank.
This looks like it does the Job of the Lexia without the need for a laptop. They are a little more expensive than the Lexia alone but cheaper than Lexia+laptop.
Has anyone used one? Do they work? Would they work for the likes of recoding the radio?
I may be needing to recode and set the parameters on a new head unit, I could just find someone to sort it for me but either a Lexia or one of these could be a useful investment.
Lasse
The ones I have seen are overpriced OBD2 units. Doubtful that you can change the VIN in a radio with these.
A ten year old laptop (Pentium M, CoreDuo) with an ok battery costs <100 Euro/GBP. With a lexia clone (cable) from the far east you have all the options.
'73 DS 23 pallas, '87 CX25TRD2 long, '11 C5 HDi 165 Tourer exclusive
