x 8437
Re: Citrojim's Xantia Activa, 1.9TD and Bike Tales
Davie, they look much better in a silver Activa for some reason!
x 2006
Unread post by Stickyfinger »
I think it is because the car rides quite high vrs "normal" cars Jim, it makes the wheels look bigger on an ACTIVA
x 8437
Stickyfinger wrote:I think it is because the car rides quite high vrs "normal" cars Jim, it makes the wheels look bigger on an ACTIVA
Yes, I'm wondering now if when wearing those wheels and tyres there may be an advantage in lowering the ride height a tad...
x 2006
Is that easy to do ?
x 8437
Stickyfinger wrote:Is that easy to do ?
Yes, if you have a ramp it is not hard. Just loosen the clamps around each Anti Roll Bar that transmits height position to the height correctors via the dog bones...
daviemck2006
x 485
Unread post by daviemck2006 »
The more I look at mine the more I think it would look better a little lower.
Sent from my SM-T705 using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
elma
x 284
Unread post by elma »
I would imagine that if you set the car to the standard height with the normal measurements it will lower it by just the right amount.
I'm wondering if this will affect the ride at all? We all know raising a Xantia to off road height makes it hard so possibly lowering it will make it softer.
x 8437
James, it'll be a good experiment to try...
Main risk is going too low and bottoming...
daviemck2006
x 485
What is the actual correct height, and how do you measure it?
Peugeot boxer 2016
In the family
Mandrake
x 695
Unread post by Mandrake »
daviemck2006 wrote:What is the actual correct height, and how do you measure it?
These should answer your questions, the first in particular, but the others included for interest. :)
https://dl.dropboxusercontent.com/u/782 ... ension.pdf
https://dl.dropboxusercontent.com/u/782 ... ontrol.pdf
https://dl.dropboxusercontent.com/u/782 ... l%20SC.pdf
Of course you don't need the fancy tools that Citroen claim you do. :lol: All you need is an 11mm socket and ratchet with a small extension, and a little cunning to make small careful adjustments...
The other important thing to getting it spot on is always take two measurements - one after it corrects itself down the other after it corrects itself up and take the mid point between the two as your measurement. This eliminates the hysteresis in the mechanism which would otherwise skew your reading quite a bit.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
daviemck2006
x 485
I think I understand all that, certainly understand enough to measure it. Mow I need a 4 post ramp, or one end on the ramps and jack the other end and let it down onto blocks a similar height. Presumably the car would have to be level to get an accurate measurement?
Peugeot boxer 2016
In the family
x 5679
You're not going to start slammin' Activas now are you.
Next thing you'll be sticking pineapples on them :(
x 8437
daviemck2006 wrote: Presumably the car would have to be level to get an accurate measurement?
Yes, it does help a lot... Be aware the adjustments are very critical and leave plenty of time on an Activa for things to settle and to get a true height. I find it best to go high, then low, high and then normal again before being satisfied with a new height setting...
It ccan be a frustrating and lengthy job to get it all spot on and then, again on an Activa, you hope it's not caused it to lean :twisted:
Adjusting Activa lean is real 'fun' :wink:
x 8437
myglaren wrote:You're not going to start slammin' Activas now are you.
:rofl2:
elma
x 284
I can't tell from the pictures but if the wheels are bigger and the tyres are lower profile then a slightly softer ride would make everything the same. Could be good, possibly damping may need refining but I'm sure could be achieved fairly easily.
