RT6 2.75.c.5 Firmware / Software Download
Jul8617
Re: RT6 2.75.c.5 Firmware / Software Download
Hi Paul. I’m so happy to read these posts about 2.75.c.5 firmware. Indeed since 2 weeks I try to fix trouble of SD card but with 2.86. My rt6 is still black and rebooting during usb installing try on a new SD card. So I hope 2.75.c.5 which is my native version, installing will succeed. Could you please share download link for 2.75
. Thanks so much. Signed a French desperate Citroën fan. Regards
- x 1942
You may have hardware problems with the RT6 that can't be fixed with just a new CD card. Bear that in mind.
2.75 doesn't seem to have been a public release, see https://frenchcarforum.co.uk/forum/view ... ce#p838347
I have 2.77, 2.80 and 2.85 though.
Jul8617
Thank you Paul for your answer. 2.77 would be much appreciated
I think to be exactly in the same situation as the member “DPM” at the beginning of this topic. Have a good Sunday. Julien
- x 1942
Check your PM.
Jul8617
Many thanks Paul for 2.77 download link. It was a success
still some tunings to perform (maps, bips, …) but the most important is the reborn of the rt6. Thanks a lot again
Mateo87
Hi, I need 2.77 too, as sd card is corrupted in my c4 Picasso 2013. Can someone send me link please, it's so sad driving without radio. Thank you
- x 1942
@Mateo87
Check your PM.
Check your PM.
Mateo87
Thanks Paul, what a releive
Mateo87
Unfortunately it give me: error during flasher loading. What is wrong? USB is 8GB. Sd card is industrial one. Is problem that maybe radio was updated before to higher version?
- x 1942
I don't know. Why did you ask for 2.77 if you didn't know what version was already fitted? I suspect that trying a later version won't work though.
Mateo87
I hoped I could program after with diagbox.
Anyway successfully installed 2.86 version, but now more programming to do with usb.
Thanks anyway
Thanks anyway
Pmm_P
Hi Paul,
Jumping in this topic that I’ve been following to try and fix the RT6 in my 2013 308SW.
The radio has started to fail more frequently as time goes by and it keeps rebooting with the Peugeot logo on and off.
Sometimes it switches off by itself and reboots and I can ear the fan kicking in for a second and then off again but it’s not making noise trying to eject a CD.
Do you think this can be fixed by replacing the SD card?
The firmware installed at the moment is 2.70.E.3
Could you please point me to the correct firmware version to install?
Thanks in advance
Thanks in advance
- x 1942
As it's sometimes working my first step would be to clone your existing SD card onto a new card. I used a program called Minitool Partition Wizard to play around with partitions on the SD card in the SMEG+ system in my 2015 Peugeot 308 and I'm pretty sure it can clone as well.
Even if your old SD card isn't good enough to clone you can still use the new card from first principles. You should also think of doubling the size for its replacement.
Pmm_P
Thanks for the advice.
I’ll pull out the radio and try to clone my old SD.
I believe that by doing so, I’ll also keep all the settings and configs, not loosing the parking sensors, Bluetooth and button functions, correct?
- x 1942
I believe so, yes.
