x 8410
Re: Citrojim's Xantia V6, C1 and Activa Tales
Post by CitroJim »
That's a much better excuse for not washing a car than mine Steve :lol:
I do know what you mean though, there's always something that needs doing however hard you try to keep things under control...
Next week it is for both of us...
x 5672
Post by myglaren »
Maybe Jim - now I have new lights and a switch to fit in the bathroom for her.
And she's just had to have a new boiler, last Monday, two weeks after having solar panels installed and a month after having a new washing machine to buy.
Manager to repair her tumble dryer, cooker and dishwasher.
x 3296
Post by Hell Razor5543 »
You can get micro fibre mitts from Poundland.
x 1994
Post by Stickyfinger »
You just have to put this on encase your spotted in there by someone you know
x 8410
Post by CitroJim »
Stickyfinger wrote:You just have to put this on encase your spotted in there by someone you know
:rofl2: :rofl2:
Don't even know where our nearest is :roll:
It'll be Halfrauds or on-line... I need to visit Halfrauds or the Go Outdoors shop next door for some winter waterproof biking gear anyway so that'll be an ideal time to look for the necessary cleaning tackle..
Fixed a little issue on the Activa this afternoon... I'd noticed a slightly sticky idle control valve recently that causes the idle to sit a bit high on occasions and was worried it might cause a few issues with the MOT emissions check.... Although the valve is hard to remove without a lot of disassembly I managed to get some lube into it by slipping off the boost sense pipe directly opposite it and spraying some WD40 into it via the boost sense spigot...
A few cycles of the idle control valve actuator test on the ELIT got it working nicely and a decent engine test seems to indicate all is good...
Also happy to see the oxygen sensor cycling nicely...
MikeT
x 232
Post by MikeT »
CitroJim wrote:I also have a smaller rechargeable LED floodlight on a stand for illuminating the parts the big flood won't reach...
I need to get me one of these but after researching, seems they're not all made equal. Some have multi-leds, others have singular led, some skimp on driver (10w driver powering a 20w led) and then there's the rechargeable battery to consider. All clear as mud to me at the moment. Is 10W adequate or should I seek higher power?
x 8410
Post by CitroJim »
Mike, this is the one I have
http://cpc.farnell.com/unbranded/ledrcf ... dp/LA05185
It's a multiple LED array and shockingly bright... Battery lasts well too... For the price it's not at all bad really... I'm happy.
They also do a 20w one too
http://cpc.farnell.com/eterna/ledrcf20/ ... dp/LA05641
Although they say the 10w is unbranded it is in fact an Eterna, the same as the 20w version...
MikeT
x 232
Post by MikeT »
CitroJim wrote:Mike, this is the one I have
Cheers Jim. Helps me a lot.
superloopy
x 19
Post by superloopy »
Specs look similar ... only difference i can see is on number of batteries supplied on the 20w (4 v 2). Is it purely down to recharge speed (10w taking longer) or am i missing something?
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
x 8410
Post by CitroJim »
Happy to report my Activa is good for another year after passing the MoT today :-D
x 8410
Post by CitroJim »
And passed with a clean sheet :-D
Chris570
x 36
Post by Chris570 »
CitroJim wrote:And passed with a clean sheet :-D
Mot station out of toner?
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
x 1994
:rofl2: :rofl2:
You where lucky Jim.....the car should be scrapped the condition its in :)
x 8410
Post by CitroJim »
:rofl2: :rofl2: No, but I see the MOT Receipt format has changed since last time. Now portrait rather than landscape...
Stickyfinger wrote: You where lucky Jim.....the car should be scrapped the condition its in :)
I know, I really do need to wash the poor thing.. She does look a bit scruffy at the moment :oops:
Zelandeth
x 1605
Post by Zelandeth »
You'll have to bring her over one of the days Jim! No shortage of cleaning supplies here (my garage looks like an Autoglym advert I reckon...), and that's one of the things I really quite enjoy doing.
Spent seven or eight years of Saturdays valeting the rolling stock at the car dealership I used to work at, so have a pretty good system worked out generally!
Current fleet:
