A very bad Birthday indeed.
x 1911
Re: A very bad Birthday indeed.
Post by Paul-R »
falling-out-with-my-car wrote:I'm going to strip my car down tomorrow and inspect the casings I may be able to fibreglass them to repair them (I hope).
Don't use glass fibre or ordinary body repair stuff, it's too stiff and doesn't adhere properly. You need the proper two part plastic repair glue for bumpers. If you put "plastic bumper repair" in to Ebay's search box (less the quotes) you'll see what comes up.
The type you want comes in a two part syringe which mixes equal amounts of hardener and adhesive. They tend to come in kits with mixer spatula and some mesh to add strength to the back of a bumper but for a radiator cowl you won't need this.
I've no experience of the ones which say "filler" in their description but I doubt they have the strength you need.
x 1911
Post by Paul-R »
Jaf wrote:...put petrol in a diesel ... car...
I think some people make this mistake once be it at an early age or a later age.
I did this for the first time in nearly 50 years last year. I went to our local Tescos and filled up the Xsara prior to a trip down to Somerset (to see the Dismaland experience). I picked up the nozzle I normally use and just about finished filling the nearly empty tank when I realised it was petrol! I phoned my brother to come with his fuel pump and empty jerry cans and then pushed the car to one side and waited for him to arrive.
We were able suck nearly all the liquid out, actually slightly more than the petrol I put in, plus some of the four or five litres of diesel that were in to start off with (the fuel warning light had been on). In total about 43 litres. I then completely filled up with diesel to flood what petrol remained and, long story short, set off about two hours later and in a lot more of a hurry than originally planned!
In my defence they had changed the pumps at Tescos since I had last been there and had put the diesel nozzle in the middle of the two petrol nozzles. What kind of sense does that make even for those who've never been there before? I mean, you would surely put it to one side or the other of the two petrol nozzles.
Two postscripts. I'm using the petrol diesel mix, further diluted with equal quantities of fresh petrol, in my situpon grass mower with no ill effects apart from a slight smokiness.
Secondly I'm glad it was the Xsara as the flexible tube on the pump was able to get right inside the tank to scavenge the mix out. I recently did the same thing to my 2003 C5 (filled it up before I knew it was going to be replaced - d'ohh!) and had to admit defeat with about a quarter of the tank left as there was some kind of plate in the way. Doubly so with the 2013 C5 as I can't even get a hose past the neck due to fuel misfiling device!
x 25
Post by falling-out-with-my-car »
Paul,
I don't want to ramble on to much about running petrol in a diesel car but it is possible with a
Bosch fuel pump and no other make to run up to 10% petrol, so if you know what amount of petrol has been added
to a diesel car with a Bosch pump (only) NOTE A LUCAS/CAV PUMP WILL PROBABLY BE DAMAGED AS IT WONT LUBRICATE THE PUMP PROPERLY.
the cleaning out process is a little less strenuous.
I used to add 10% petrol to my veg oil in the winter time as veg oil has no antifreeze in it.
I don't do that anymore strictly diesel these days.
I stay away from Tescos fuel here because I don't get good mileage on it compared to Shell.
x 1911
Post by Paul-R »
Surely that is applicable to the XUD engine only? The Xsara may be fifteen years old but it still had the high pressure HDi engine in it. Anyway it's done about another 10,000 miles since then. Petrol percentage will have been a lot less than 10%, probably nearer 3% - 4%.
Just to check I've just pulled out my 2015 receipts. I put 39.71 litres of petrol in, emptied it as best I could, and then put 43.67 litres of diesel to completely fill it up. The tank normally takes about 54 litres so possibly the ratio is nearer 10% than I first thought. Anyway, that's all in the past now.
x 1911
Post by Paul-R »
Oh, what the hell. Even more completely :offtopic:
Ramble On is great track by Led Zeppelin. Have a hankering to listen right now...
x 8266
Post by CitroJim »
Paul-R wrote:Oh, what the hell. Even more completely :offtopic:
From an Admin/Mod point of view, always happy to let threads ramble on as they can become very interesting indeed as a result ;)
x 2941
Post by Gibbo2286 »
I like the "It's Tesco's fault." surely the colour of the hoses is sufficient to warn which you're going for. :shock:
x 6953
Post by GiveMeABreak »
I got caught years ago on the Xantia 110 HDi - flaming Tesco again (it literally very nearly was flaming), when I used to use supermarket fuel - not anymore. They changed all the pumps / colours and I ended putting petrol in. My mech wondered how I hadn't exploded my way the 50 miles to his garage on half a tank of petrol and half diesel!! Suffice it to say, fuel pump failed a few weeks after draining the tank, requiring a new one! :spineyes:
BenC5HDi
Not Mike
x 45
Post by BenC5HDi »
I put petrol in my diesel Berlingo about 4 years and 55k ago. So far no ill effects.
I love Citroens colour coded warning of my *diesel* filler cap insert though... Image
Sent from my SM-N9005 using Tapatalk
x 8266
Post by CitroJim »
That filler cap is just confusing...
BenC5HDi
Not Mike
x 45
Re: RE: Re: A very bad Birthday indeed.
Post by BenC5HDi »
CitroJim wrote:That filler cap is just confusing...
Yes, isn't it just!
x 1911
Post by Paul-R »
Gibbo2286 wrote:I like the "It's Tesco's fault." surely the colour of the hoses is sufficient to warn which you're going for.
Nope.
GiveMeABreak wrote:I got caught years ago on the Xantia 110 HDi - flaming Tesco again
It really is Tesco's fault :rofl2:
x 1981
Post by Stickyfinger »
BP a few years ago switched ALL the handles/pipes to a Green plastic to "fit" with their new corporate colours, just the clip on cover showed Black/Green.
Result, as you imagine.
x 1911
Post by Paul-R »
I hope they had their arses sued off them for that.
x 1981
The recovery guy said they had done hundreds.
The way it was resulted in Diesel going into Unleaded cars so not that many serious fillings (destroyed pumps/injectors) happened. Just a lot of pumping/filters and injector cleaner.
