x 8386
Re: Citrojim's Xantia, C1 and XM Tales
That sounds like a potentially nice one at a bit of a price Mike :-D Shame the price doesn't include removal of the dented sill and a belt change :(
Identical to mine except it has a V6 8-) Shame the vendor does not seem to say if it has a leather interior. I guess as it's a V6 it will.
I'm concerned it only has eight spheres though. Mine has 10!!!
And that it has shrapnel damage. I take it that's just a bad translation of stone chips...
Mark, the price difference 1750 Euros vs. 3400 Euros with belt and dent done might give a hint at how much a V6 belt swap can cost...
x 1460
Unread post by xantia_v6 »
"dont sièges en cuir réglables" = electric leather.
That seems to be a reasonable price for an Activa V6 in France (except those with intergalactic mileage or documentation irregularities). Still cheaper than buying a TCT and converting to ES9
Mandrake
x 695
Unread post by Mandrake »
CitroJim wrote:Took my V6 to karate this morning. It's definitely running very beautifully and better than it was before the new belt and all the recent TLC :-D
Is it the new plugs, all the cleaning of the inlet tract or the fact the engine ECU has been reset for the very first time in my long ownership of the car? It was the first time for me the battery had ever been disconnected...
It isn't valve timing as with the old belt the timing was observed to be spot-on..
Simon, I'd be interested in your views as the difference is tangible :)
Interesting Jim - you'd have to describe the nature of the difference in performance in a bit more detail to make a guess, but it could be a combination of all three.
As you say it's probably not the valve timing, assuming all the cams were able to pin perfectly - on my old V6 the timing was basically right, but two cams were about 1/4 of a peg out so wouldn't quite pin down until being tweaked - after we fixed that there was little if any improvement.
Cleaning the intake tract around the butterfly can make it a little bit more snappy and responsive when you take off from stationary with a very light throttle as a gummed up butterfly introduces some dead band in the bottom end of the throttle range.
How were the old spark plugs, and did you change them to a different type ? I've come to the conclusion recently that the ignition system on the ES9J4 is a wee bit marginal for the job at hand in terms of spark voltage/strength - it's a very high compression ratio engine (which means high peak cylinder pressures and high required spark voltage) plus its waste spark which increases voltage demands further as the spark has two gaps to jump in series. When everything is in tip top shape I'm sure its fine but throw worn plugs, leads or coils into the mix and an intermittent misfire can easily develop especially at full throttle...
The spark plug leads don't seem as tough and reliable as you'd hope - I had quite a bit of trouble with the plug leads on the old V6 (the originals had intermittent breaks in two of the wires that could be measured with a multimeter and one replacement set were faulty in some way too) and I'm pretty sure that the leads on the new V6 are faulty too. A couple of times now the performance of new V6 has gone down hill quite a bit especially at full throttle and I need only wiggle the broken spark plug lead guide around on top of the manifold and the performance is instantly back to normal - so I'm guessing it too has intermittent breaks in one or more wires. :roll:
Is it possible one of your spark plug leads is the same and has an intermittent internal break when flexed in a certain way which has just found itself sitting in a more favourable position after the manifold has been out and gone back in ?
The battery off ECU reset definitely can make a difference - but only in cases where the ECU has learnt bad data due to a pre-existing condition. For example when I first got new V6 the performance was really flat and poor all the way that I drove it home, until I did an ECU reset when it came back to normal for a few weeks.
I'm not sure how it had got itself into that state - one theory is that a combination of very hot (28+ degrees) sunny weather and the long trip back from Plymouth on 95 octane fuel was enough to force the ECU to knock the timing back quite a bit, since knocking can be worse with very hot temperatures...
If I had to guess I would say the change that you see is mostly ignition related, as I'm certainly seeing a big change in performance with my new one just by moving the plug leads around a small amount...if the improvement in performance on yours disappears again I'd suggest changing the spark plug leads next time the manifold is off if you've never replaced them before...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 8386
xantia_v6 wrote:"dont sièges en cuir réglables" = electric leather.
Giggle translate failed on that Mike.. Thanks! You're right it's cheaper than doing an ES9 conversion!
Simon, the thing seems smoother, livelier and more responsive now. I could of course be placebo but it even sounds nicer..
The plugs looked fine but they’d been in a long time. For all the 30,000 miles I've done in the car since I've owned it and whatever they'd done previously so they were well due a change. Not sure if the interval when they should be swapped now.
I'm now running some posh Bosch 4 electrode jobs...
One thing that prompted me to get on with the job was that she wasn't starting quite as readily as normal and as Chris will attest, one day after a not overly long rest at WFA's Barford branch she ran on five on first startup...
Now she's a lot more eager to start and idles more smoothly..
The intake wasn't badly mucky but it got a good clean none the less. The inlet manifold gasket was fully intact. In fact I was tempted to re-use it but thought better of it and treated her to a new one...
Eyelashes is presently parked up in the V6s normal space as the V6 is going to be used for the next couple of days to take me to work and back as a shake-down for the trip to Nottingham on Wednesday...
It's a long time now since either of my Xantias have been to work!
Mandrake
x 695
CitroJim wrote: Simon, the thing seems smoother, livelier and more responsive now. I could of course be placebo but it even sounds nicer..
Sounds like you've fixed a minor ignition related misfire then Jim. :)
If the lack of power is caused by retarded timing (as was the case on my new V6 when first driven home) it makes the engine unusually quiet and smooth - so restoring normal performance by fixing whatever is causing the timing to get retarded actually makes the engine noisier and more rawty sounding...
On the other hand if the lack of power is due to a misfire the engine gets noisier and rougher when the power is lacking, especially under heavy acceleration - fixing the misfire and restoring normal power then makes the engine quieter and smoother.
Since your engine got quieter and smoother when the power increased its a safe bet that the problem was a misfire not retarded timing.
Funny you mention starting improvement - old V6 shortly before selling it was very good at starting and caught instantly, and I think the work I did on the ignition system was a major part of that as it had new plugs, plug leads and new coil pack in it.
On the other hand new V6 doesn't start quite as well - it always starts but it doesn't catch quite as quickly and doesn't start quite as eagerly, and I think the reason is ignition, and possibly the plug leads.
Do you have the exact model number of the plugs you fitted Jim ? I'll be wanting to replace the plugs when I do the leads in a month or so and was going to stick with Bosch FR8KDC but I'd consider a four electrode type if you're getting good results from it...
Simon
1978 CX 2400
x 8386
Thanks for that Simon :-D It all makes a lot of sense. I really appreciate your views on this.
Mandrake wrote: Do you have the exact model number of the plugs you fitted Jim ? I'll be wanting to replace the plugs when I do the leads in a month or so and was going to stick with Bosch FR8KDC but I'd consider a four electrode type if you're getting good results from it...
They are Bosch Super Fours HR78X.
Here's an ebay listing for them.. Good price too!
EDIT: Just noticed the ebay picture is wrong!!! The picture shows ordinary single-point sparkers...
Mandrake
x 695
Thanks Jim, are you sure that's the right code though ? According to the following page, the HR78X is a tapered seat:
http://www.gsparkplug.com/shop/bosch-hr78x.html" onclick="window.open(this.href);return false;
Here's the original Bosch FR8KDC for comparison which is a gasket seal type:
http://www.gsparkplug.com/shop/bosch-fr8kdc.html" onclick="window.open(this.href);return false;
Also the one you quoted is a 7 heat range instead of 8 so slightly colder. Probably fine if you do mostly long trips but for my typically shorter slow speed trips it might suffer from carbon build up on the insulator like the FR7DC+ did.
I'm sure there is a version of the super fours in 8 heat range with gasket type seals though, I'll see if I can find the correct part number.
Simon
1978 CX 2400
DHallworth
x 167
Unread post by DHallworth »
Timing belt kits are available from Euro Car Parts for £199 at the moment as they're on promotion:
http://www.eurocarparts.com/ecp/c/Peuge ... f3a&000332" onclick="window.open(this.href);return false;
I paid £250 for the one I fitted to the Activa.
The tensioner was SKF as were the idler pulleys. It's SKF who make the genuine ones so it's all genuine kit that's in the box.
Time wise if it's the first V6 belt you've done then it might spread into a Sunday if you start on a Saturday. I've done 4 of them now and can quite easily get it done in an afternoon.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8386
DHallworth wrote: Time wise if it's the first V6 belt you've done then it might spread into a Sunday if you start on a Saturday. I've done 4 of them now and can quite easily get it done in an afternoon.
That's good work David :-D Excellent going =D>
You must work a lot faster than me as I'd take a day at least and I've done enough of them... Perhaps I drink more tea during the job than you do :lol:
Although again I never rush jobs like that and really clean and shine things and do the odd 'value added' like taking the alternator off to clean it of spilt LHM as I go along and that takes up the time...
x 8386
Mandrake wrote:Thanks Jim, are you sure that's the right code though ? According to the following page, the HR78X is a tapered seat.
Got me thinking now Simon!
I must admit I took the ebay ad from ECP at face value really. They said they were right and I didn't really question it.
Colder is Ok for me as mine only does long trips normally.
My old ones were washered FR8KDC..
Is there a problem in using taper seal plugs in place of them? Got me a bit concerned now...
x 1460
Yes. Taper seat pugs require a taper seat. They will seal OK in an aluminium head by deforming the shoulder of the hole, but they may not have enough contact area to cool themselves.
Better get some washer seal plugs...
DHallworth
x 167
Jim,
If I see any leaks then it turns into an all weekend affair cleaning everything :lol:
Last one I did everything seemed dry on and I was only doing it on a car I was getting rid of so it got a quick belt thrown on it.
If I was doing the Activa or the XM I'd be taking everything off for a clean before refitting :lol:
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 8386
Thanks Mike, will do!
Bit surprised that a big firm like ECP can advise the wrong plugs!
I'll not drive too sportingly until I've go the right ones in then...
Any advisories as to a recommend set? Simon?
That'll be the inlet manifold off again :twisted:
x 8386
DHallworth wrote:Jim,
That's exactly what happened with me this time. I really didn't realise how bad the pump leak was on mine... That put quite a lot of time onto the job.
PavlosV6
Unread post by PavlosV6 »
CitroJim wrote:Thanks Mike, will do!
Old V6 is doing very nicely on a set of NGK BKR6EZ.
Paul
'97 Xantia MK1 V6 Exclusive in Mauritius Blue - 205K - "Old V6" - A new life begins.....
'06 Picasso Exclusive 110 in Mediterranean Blue - 106K
'14 308cc 2.0HDi 163 Roland Garros in Pearlescent White - 7K
