Unusual/Interesting Engines/Motors
Dormouse
x 696
Re: Unusual/Interesting Engines/Motors
Unread post by Dormouse »
This engine was being discussed this week
However, the really interesting bit is this.
x 5679
x 8165
This may raise some scepticism!! :-D
So good its appeared in two of the previous three posts!
x 8165
So it has, I missed the original post I'm afraid but better twice than never!! :-D
mickthemaverick wrote: 20 Oct 2024, 13:06 So it has, I missed the original post I'm afraid but better twice than never!! :-D
New audience every day Mick :-D Not averse to a bit of repetition myself!
x 8165
mickthemaverick wrote: 07 Aug 2024, 17:35 Food for thought? :-D
There is a follow up to the above video released today: :-D
x 8165
Another view about the 6 stroke engine : :-D
Sloppysod
x 403
Unread post by Sloppysod »
Does this belong here, after all its is an interesting engine.
I think it is very interesting and shame it does give alot of power.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 2367
Unread post by MattBLancs »
Sloppysod wrote: 06 Aug 2025, 11:45 Does this belong here, after all its is an interesting engine.
Definitely interesting and definitely an engine: that's a Stirling Engine. Runs in a temperature differential between two heat sinks (e.g. a hot brew and a colder room)
Think there has been some commercial applications: the domestic scale CHP (combined heat & power) setups - WhisperGen??? Units were a Stirling Engine inside, I believe
Vic Evans
x 178
Unread post by Vic Evans »
We've got fans that sit on our wood burning stoves working on same Peltier thermo electric principle.
Sloppysod
x 403
Vic Evans wrote: 07 Aug 2025, 16:53 We've got fans that sit on our wood burning stoves working on same Peltier thermo electric principle.
I've seen them, but i thought they somehow worked on thermal currents driving one of the fans.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 1952
Unread post by Paul-R »
I thought they were thermally driven as well.
x 3298
Some components have 'reversible' properties. When you pass an electrical current through a Peltier semiconductor it pumps heat from one side to the other (really strange to hold one between your finger and thumb and have your thumb get colder while your finger gets warmer). Conversely, when (provided it is fitted the correct way round) one side of the Peltier semiconductor is warmer than the other side it generates an electrical current. This property allows heat driven fans to work. Most live-aboard boat owners will have one or two such fans on their stoves, as it helps to circulate warmth without needing extra wiring.
x 2367
So, my understanding is its two different technologies, though both are effectively "moving heat energy" between the two heat sinks:
Stirling Engine has a "displacer" piston and air inside the engine is heated (by the hot sink) is then moved adjacent to the cold sink when heat energy is rejected from the air into that sink.
So there's moving parts involved in this process and indeed a moving "fluid" too.
Whereas the peltier effect generates electrical current and it's a conventional DC motor using that energy that then spins the fan. No movement in the bit sat between the two heat sinks.
