x 3296
#1 is a Hellerman sleeving tool (sometimes known as the "honeymoon tool"!),
#2 looks like wire strippers,
#5 is a nut splitter,
#9 is a plumb line.
x 3565
#4 looks like a hub socket
x 7165
I'll bag this although the hub socket could also apply but...possibly...looks like a ball joint removal socket for those French things with unremovable ball joints!
x 8126
#9 looks like a plumbline? and #5 maybe a pipe drill for a T joint?
x 5673
I have one of these in regular use
And a couple of these in a more modern case
Used some of the others and my dad had a few of them too.
x 7165
Now that is what it says on the tin. A RARE Vintage Stanley Chalk-o-Matic 47-050 Chalk Line Reel 50ft Made In USA yours for £8.50 plus postage on e-bay! Comes with a FREE bottle of the original Stanley chalk!
x 2938
I just recently sold my version of number one, a grommet stretcher for wiring etc.
I've got a number four in my toolbox, for taking off those damned tight bottom ball joints
harryp
(Donor 2022)
x 73
Unread post by harryp »
No 7, bench stop?
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
x 2938
No 3 looks like a specialised insulation stripper and the name stamped on it is 'Urmet', Urmet make those door entry kits that you let your visitors in with when you've confirmed who they are.
x 3296
mickthemaverick wrote: 27 Sep 2019, 20:31 A superbly engineered missile, its name was borrowed by Richard Noble for the current World Land Speed record car which is destined to eventually reach 1000mph in South Africa having first set a new record in the region of 800mph. The project ran into financial difficulties after the test runs at Newquay and was bought out by a Yorkshire businessman and is now back on course. I am a founder member of the supporters club and have been involved since 2006. I won't put any pics here but if you are interested you can now find all the details at www.bloodhoundlsr.com. Plenty of good stuff on there especially Andy Green's contributions. If you are not aware Andy holds the current record from Thrust SSC and the entire Bloodhound car has been designed and built to fit and suit him.
There was another reason Richard Noble chose the name Bloodhound; one of the people who helped with Thrust SSC (and is involved with Bloodhound SSC) is a gentleman called Ron Ayers. Ron had been head of Operational Research at the British Aircraft Corporation (Guided Weapons Division) in Bristol, and was the chief aerodynamicist on the Bloodhound 2 anti-aircraft missile. (Information gleaned from Richard Nobles' book "Thrust").
https://en.wikipedia.org/wiki/Ron_Ayers
One of the mist incredible (to my mind, at least) was the visible shockwave as Thrust SSC went supersonic;
moizeau
x 423
Unread post by moizeau »
1 - I had no idea until Gibbo enlightened me
2 - Self adjusting wire stripper
3 - A pipe flaring tool?
4 - Got one, ball joint socket
5 - Nut splitter
6 - A staple?
7 - A security lock?
8 - If it's mercury inside? A rotational switch?
9 - Chalk line
10 - Tin flashing bender?
Pete
x 8126
Hell Razor5543 wrote: 28 Sep 2019, 18:29
One of the most incredible (to my mind, at least) was the visible shockwave as Thrust SSC went supersonic;
Quite correct James but that is actually the same reason, I just didn't expand on it to try and avoid waffling on about our current project as I am prone to do!! :-D :-D
x 3296
Don't worry about waffling on over things you are enthusiastic and knowledgeable about; we ALL do it here!
x 8126
Good point James, you'd think I would have realised that by now #-o
x 3296
mickthemaverick wrote: 28 Sep 2019, 18:43 Good point James, you'd think I would have realised that by now #-o
Reading your signature reminded me I used to be schizophrenic, but all five of us are fine now!
