ozfrog
(Donor 2026)
x 76
Unread post by ozfrog »
MattBLancs wrote: 21 Aug 2026, 18:20
EDIT: Lack of functioning air conditioning was key downside of otherwise comfortable trip in the "back up option" grey 308 SW.
I know you people are having an exceptionally hot summer, and it’s very uncomfortable for you. But it’s still funny to read about the lack of a functioning air conditioner in the car ruining your car trip.
Sorry for your discomfort. And sorry for being so amused by your story.
Cheers,
Andrew
x 8403
ozfrog wrote: 21 Aug 2026, 22:56 I know you people are having an exceptionally hot summer, and it’s very uncomfortable for you. But it’s still funny to read about the lack of a functioning air conditioner in the car ruining your car trip.
Indeed, it's been quite a pleasantly warm summer here and I've loved it :-D Thing is Andrew, that Pomland is not geared up for reasonably warm dry summers and even moreso, the Poms themselves are not in any way acclimatised and have struggled somewhat.
Given a few more summers similar to what we've just had, I'm sure both our infrastructure and the inhabitants of this fair isle will adjust.
The problem I find with modern cars is they are designed to be climate-controlled and when the aircon gives up it all fails. Opening all the windows just doesn't cut it. My AX was never designed to have aircon and opening both front windows and the sunroof when it's knocking on 35 degrees produces an agreeable place to be; my Picasso just becomes a noisy, turbulent mess with the windows open. Like living through a cyclone...
x 2347
Unread post by MattBLancs »
Oh yes, I know it's not "proper hot" :) and, yep it's definitely us not used to any sort of higher temperatures. 15-20 °C is "just nice", above 25 or so - I'm flagging a bit.
I do realise those in Europe and indeed down under will have another 10-15 degrees above that and wonder what the fuss is all about.
Good theory about cars never designed to have air con Vs modern "climate controlled" vehicles
Huskyxantia
x 912
Unread post by Huskyxantia »
I love the old type of air con , all windows down and away we go !
:-D
x 2347
Yep quite a bit of that in the go again today too! About 160 miles covered today, so just under 100 to go in the grey 308 SW :)
Just stopped for lunch.
Red 308's new clutch bleed thingame has a tracking number, so hopefully Royal Mail get it to me soon
x 2347
587 miles covered since Friday, rather warm and sticky in the Grey 308 again and a quick detour to GSF Norwich to pick up this magic position:
https://www.gsfcarparts.com/products/dp ... rEQAvD_BwE
Unfortunately didn't make an appreciable difference on the new message we've picked up:
Risk of particle filter blockage. Please refer to owner's handbook
Mostly appearing very briefly on medium throttle (heavy throttle didn't guarantee it appeared, which seems odd) I guess we're seeing high DPF differential pressures and it's momentarily triggering that message. Will see if I've enthusiasm for a diagnostic session this evening :)
Huskyxantia
x 912
Just what my 308cc has been doing the can you purchased was a good price , let us know if its any good.
:-D
Huskyxantia
x 912
As for the hot weather I love it , my body dont lol
:-D
x 2347
Huskyxantia wrote: 24 Aug 2026, 18:34 Just what my 308cc has been doing the can you purchased was a good price , let us know if its any good.
I think this wants the DPF swapping (or professionally cleaned out, off car) it's done 132,588 miles now - I had messages previously (from memory, a different message from this time?? Will check this blog as am sure I logged it here)
I've got an aftermarket DPF "on the shelf" - bought when the messages appeared previously - that'll get fitted this coming weekend hopefully.
I'm not sure the potion has done anything to be honest! :)
Huskyxantia
x 912
Temporary fix the can, if you keep it this way it soon works out more then buying a new one , if it was done once a month for over a year and a half ive even tried to trick the dpf by resetting with diagnostic, didn't work , ive got my eye on one its about £127 that's just for the bottom part not the whole canister , then theres the risk of the lower sensor nuts or bolts being a pain to get undone, everything has a service life I guess
:-D
Huskyxantia
x 912
Mines on 156k + ...... speaks for itself.
:-D
x 2347
Ah, so we are in similar boat with mileage (within 20k of each other, pretty close. And neither car in the "first flush of youth" :)
I miss remembered - it was "risk of blocking" message previously:
viewtopic.php?p=790758#p790758
No fault reading tonight, knackered (and giddy boys to calm down for their bedtime!)
Huskyxantia
x 912
Yes risk is just that ,, a risk , if it was blocked I think the car would not want to run , good luck with the bed time thing , I remember all that when my lot were little .
:-D
Huskyxantia
x 912
When ever I've run live data on the car when this warning pops up the soot content has never been over 20% think one time it was 14% full of soot then a week later 8... the sensors could be the main factor also due to age and service life .The weird thing is when I had my 207 it had the same engine but a lower tax band , I must of put 15000 miles on it in my ownership, it never once nagged about dpf stuff at all
:-D
x 2347
Huskyxantia wrote: 24 Aug 2026, 20:37 Yes risk is just that ,, a risk , if it was blocked I think the car would not want to run , good luck with the bed time thing , I remember all that when my lot were little .
Agree, but if it's unable to regen then it'll slowly build up and up. I can't recall from memory what percentage full readings I've seen, but think there's a "too full to regen" figure where I'd think it was in limp mode.
The car did it's usual 28 miles each way commuting yesterday without a single instance of the message popping up.
Will try and get it on Diagbox soon :)
