Merged Lexia & Diagbox threads
Mandrake
x 695
Re: What is Bashe 5? + Diagbox Info
Unread post by Mandrake »
I don't have 6.01 installed (I'm on 6.35) so I'm not sure whether a list of files would be that helpful, but now I know you're using a standard 6.01 install here is the basic process:
0) Unplug the interface and make sure it is not plugged in until the very end.
1) Run the main installer, after it installs, launches Diagbox and prompts to activate, exit the app without activating.
2) Extract Lexia.rar to C:\, extract PP2000.rar to C:\, extract PPDIAG.rar to C:\APP.
3) Copy the file PatchV6 to C:\AWROOT\BIN\FI\CACHE, double click to launch it from there, press patch, it should come up and say that its patched successfully.
4) Launch diagbox, choose manual activation, enter:
customer code: scary01
activation: 12345678901234567890123456789012
Profile: 02ffffff
Address: *
Postcode: *
Car Phone: 0
Diagbox 6.01 should now be working. For updating I would recommend to stay away from the built in internet updating feature and download scarymistake's updaters...
For each update you run the updater which then prompts to reboot, after rebooting launch diagbox and it will apply the update. Once the update is applied exit diagbox, and if you have further updates rinse and repeat.
After you're finished everything but before you plug in the interface, open a file in notepad called:
C:\AWROOT\BIN\LAUNCHER\AP
It should be a text configuration file, near the beginning find the line MAJ_COM=TRUE and change it to MAJ_COM=FALSE then save the file.
Only now connect the interface. When using Lexia, launch Diagbox with the interface connected, however just before you press the Lexia button unplug the interface and plug it back in.
Hope that helps. :)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
c.morewood
x 55
Unread post by c.morewood »
Yes it does .. Thanks Simon
Just how much of the Diagbox programe is available on the internet.. I've just started exploring it and come across diagnostic documentation and mechanics handbook can I use the internet to get to these documents or is it advisable to avoid any internet contact?
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
Mandrake
x 695
As far as I know the diagnostic documentation and mechanics handbook in Diagbox is internet based and requires legitimate registered copies of Diagbox, so I don't think we're able to use them. At least I haven't found a way. Sorry. :(
If you're looking for general diagnostic/troubleshooting/repair information (eg service manuals) it is possible to find copies of "Docbackup / Sedre" on the internet (sometimes called Citroen service box) from the same sort of sources as Diagbox. It's a PITA to install and confusing to use but it is very comprehensive and useful. Basically electronic versions of the service manuals and wiring diagrams.
Simon
1978 CX 2400
c.morewood
x 55
Got that, Thanks Simon.. had a great week of installing French software!!
Thanks again for the help
'94 Fiat TipoTd 40K
jmd
Re: Lexia group discount through moderator?
Unread post by jmd »
Just got my Lexia operational to-day. Two questions - Please pardon my ignorance but-
(1) What is the R.P.O number- or where can it be found ? i have taken a chance and input the last 5 Digits of the Chassis No. this allowed the program to go forward and Run Diagnostics (probably not the correct way to have proceeded).
(2) Spare key for the car (c5 series 1) needs to be programmed...... What is the procedure for this.?
Mandrake
x 695
The RPO number is in the drivers door jam near the tyre pressures, take the first 5 digits of the long number which will be about 12 digits long.
For programming check the programming guide I posted on page two of this thread:
http://www.frenchcarforum.co.uk/forum/v ... 4&start=15" onclick="window.open(this.href);return false;
Simon
1978 CX 2400
jmd
Thanks Mandrake. very helpful....I'm probably being over cautious in using the program. I only loaded ''Lexia'' and not PP2000 -as I will only be using the program on Citroens. I trust this is O.K
oneday
Unread post by oneday »
pp2000 is for older peugeot you dont need it
306 1.4 LX MERIDIAN
jmd
Thanks ''oneday'' . I thought not, but wanted to confirm.
jmd
Attempted to reprogram a (series 1) C5 key today. All went o.k until the key-code was requested I filled in the code that came with the car, and was told that the incorrect code was entered - the code consists of four letters,(no zeros, that might be mistaken for oh's or anything confusing) simple enough you might say. Has anybody experienced this. The car was purchased second-hand a number of years ago, and the second key (without the blip) opens & locks doors, turns on the ignition,turns over the engine, but will not start the car. Perhaps the wrong code card was supplied with the car. Wondering if it is possible to get the code from a main dealer, on the basis of giving him the VIN number?
oneday
you can get the code from the bird man just pm him he will sort your code out
306 1.4 LX MERIDIAN
x 5673
jmd
Many thanks gentlemen-I have PMd The Birdman.
The Birdman
Unread post by The Birdman »
Sent Jim a pm , sorry guys i`m not on here as much as i would like , if anyone in a hurry for codes just click on links below and my contact details are there ,
Cheers Birdman
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
MonkeyMark
Unread post by MonkeyMark »
Still considering purchasing on eof these.
Whats the going price at the moment should a group discount be applicable?
Happy(ish) C8 owner.
