gustav
Re: Hydralic suspension
Can anyone help me with the original part number for the spheres in the front corners? The VIN for my car is: VF7**************[VIN obfuscated, can be read by forum staff]
- x 6957
@abyj:
(10) Engine Fuse Box, part: 6500HV, £137.53
As for the Compressor, Citroen do not list the clutch separately for the version on your vehicle (Item (6) - no part number available), but here are the compressor part numbers:
(1) New OEM Compressor (SANDEN INT- - SD6C12 1363), part: 9822826880, £1074.48
Standard Exchange Compressor (SANDEN INT- - SD6C12 1363), part: 1671553680, £579.01
- x 6957
I've moved your parts request post to the appropriate Thread.gustav wrote: 14 Mar 2025, 09:08 Can anyone help me with the original part number for the spheres in the front corners? The VIN for my car is: VF7**************[VIN obfuscated, can be read by forum staff]
(2) Front Sphere & Gasket:
OEM Original, part: 1638046780, £186.07
Citroen Cheaper Option, part: 1638378080, £89.00
Rhothgar
- (Donor 2026)
- x 221
Hi Richard.RichardW wrote: 12 Mar 2025, 18:55Can you post the VIN, I'm not as organised as Marc....!Rhothgar wrote: 10 Mar 2025, 16:47 MOT Failure on the green S1 today!
Nearside front CV gaiter
Nearside front indicator unit.
Please may I have the relevant part numbers?
Also the rev counter has stopped working. I haven't tried the fix as suggested in one post I have just read but please could I also have the part number for the sensor which sits on the differential?
TIA
Yes of course. Hope you are well.
It is VF7**************[VIN obfuscated, can be read by forum staff]
Please could I have part number for rear nearside ABS sensor also.
I think it is 4545.54 but it could be any 4545 number just about.
- x 6957
(3) Driveshaft Gaiter Kit (Wheels Side (GAITER MARK 9615128980 OR 9617245280), part: 329396, £73.92
(4) Driveshaft Gaiter Kit (Final Drive Side ((GAITER MARK 9609802380 OR 9621047580). part: 328779 (NFP)
(2) Side Flash Unit, part: 632545, £23.44
(2) Rear ABS Wheel Sensor, part: 454554, NFP
Rhothgar
- (Donor 2026)
- x 221
Nice one Marc.
Part 1 please. I thought it sounded a bit of a bargain!
- x 6957
You did say the 'Gaiter', not the driveshaft...
(1) New Driveshaft, Left, part: 3272Q7, NFP
Exchange Driveshaft Left, part: 3272R0, NFP
- x 1487
Presume item 1 on the flasher diagram.... this is 95667956 - but NFP of course! Speak to David Hallworth, he is breaking a Mk1. Sadly it's not the same as a MK2 as I think i have one of those in the garage....GiveMeABreak wrote: 14 Mar 2025, 14:18 You did say the 'Gaiter', not the driveshaft...
- x 6957
Re the Lamps, if (1), then yes, both NFP:
Left: 95667956
Right: 95667957
Left: 95667956
Right: 95667957
Rhothgar
- (Donor 2026)
- x 221
Yes it was gaiter which is why I deleted all other microfiche to avoid confusion when asking for Part 1...GiveMeABreak wrote: 14 Mar 2025, 14:18 You did say the 'Gaiter', not the driveshaft...
Have a great weekend and thanks to Richard and yourself for the indicator part number.
trollkarlen
- x 4
Whats the part no for the fuel pump in the tank ?
- x 1487
There isn't one - just a gauge unit on this:trollkarlen wrote: 14 Mar 2025, 23:37 VIN: VF3**************[VIN obfuscated, can be read by forum staff]
GORAX
- x 14
Hi together,
I Looking for Rear camera part no.
GOOGLE TRANSLATE
GORAX
- x 14
On the passenger side, only mild to cold air comes out when the heater is on. I would like to replace the flaps from the inside and need the part number.
GOOGLE TRANSLATE
- x 6957
Your vehicle was not originally fitted with a parking assistance camera so there is no part showing, and there are several types depending on the integrated system, so I couldn't tell you which one you needed as it wouldn't work without the correct ECU, programming, Head unit version and other cameras.GORAX wrote: 15 Mar 2025, 15:27 Hi together,
