True, but since it shows me the pressure on the rail I assumed it is ok.vincentfishing wrote: 30 Jan 2022, 21:40 one thing that wasnt on your list of new replacements was fuel pressure sensor, you changed everything else but not this, presume it has one?
Difficult cold start on C5 X7 2.0HDi
Lacrosse
Re: Difficult cold start on C5 X7 2.0HDi
- x 3296
Does this engine have a fuel pressure regulator? I know that members have had issues with them on older cars, and replacing them has often resolved the issues.
Lacrosse
So, no help from easy start spray.
Starting to wonder that the problem is not from the fuel and injection system...or?
Lacrosse
Yes, it has.Hell Razor5543 wrote: 31 Jan 2022, 08:09 Does this engine have a fuel pressure regulator? I know that members have had issues with them on older cars, and replacing them has often resolved the issues.
Lacrosse wrote: 20 Jan 2022, 00:21 At this point:
- Repalced all injectors with brand new ones (Delphi)
- Replaced MAF with brand new one (Pierburg)
- Replaced battery with brand new one (Varta)
- Replaced all glow plugs with brand new (although the old ones were functional)
- Replaced fuel pressure regulator new OEM
- Replaced EGR with brand new one OEM
- Replaced Camshaft sensor with brand new one (Valeo)
- Measured compression on every cylinder - No problem here / Oil level does not change
- Doing all the above didn't change anything about my problem
vincentfishing
- x 13
would suggest you have a problem with your air intake, easy start has nothing to do with fuel or injectionLacrosse wrote:So, no help from easy start spray.
Reason: Quote tags.
Reason: Quote tags.
Lacrosse
Starting to wonder if it isn't this the case:
viewtopic.php?t=60717
To much black oily goo in the inlet, an as it cools down in cold weather and overnight, its hardening and blocking the air intake...Any thoughts on this?
vincentfishing
- x 13
when you have bad build up of 'goo' in inlet(will also be in egr) and pipes it will cause loads of black smoke under accelleration(not white smoke)
vincentfishing
- x 13
this was a the state a car i bought was in before iremoved inlet /egr/swirl flaps etc, a right mess and masses of black smoke, no smoke after a few days of cleaning
https://forums.mbclub.co.uk/attachments ... jpg.90964/
- x 1938
That forum requires you to login (and hence be a member) to view.
vincentfishing
- x 13
- x 5672
You will need to download that image to your computer then upload here.
There is a guide to uploading here.
We can't just follow the link either as it requires a log in (membership) to the site.
Lacrosse
I ordered a new intake manifold. We'll see if that helps...
Steve Walsh
- x 518
Might be worth disconnecting exhaust on engine side of DPF and giving it a try before hitting it with more parts
TanT
I don't see anything here about coding in the new injectors or any electronic parts that you changed. Your ECU gets confused with replacement parts unless you tell it there has been a change the car may not start. Lexia and diagbox are cheap on ebay and better investment than guessing which part to buy next.
If you spray easy start and the car does not fire then you may have a mechanical failure such as timing. diesel engines burn almost any flammable substance thrown into it even when electrics are not working.
Good luck to anyone with similar problem!
Lacrosse
Problem still not solved...TanT wrote: 29 Nov 2022, 19:23 I don't see anything here about coding in the new injectors or any electronic parts that you changed. Your ECU gets confused with replacement parts unless you tell it there has been a change the car may not start. Lexia and diagbox are cheap on ebay and better investment than guessing which part to buy next.
Injectors were coded to car, and any part that needed coding to car was done with Lexia/DiagBox.
Problem occurs after car sits overnight or more than 5-6 hours unstarted.
Car runs fine AFTER FIRST cold start. Car starts instantly in the rest of the day.
Problem worsens when cold/icy weather comes and viceversa
