C5 V6 (2005) - turns over wont start :(
x 1490
Re: C5 V6 (2005) - turns over wont start :(
Harlequin wrote: 24 Sep 2019, 11:40 However the numbers on the side are different.
It's the wrong one then.... Ignore the Citroen part no (unless you order direct) - go off the long number printed on the BSM. Refit the original, see if the wipers stop. Then jump a 12V supply direct on the fuel pump and see if it will run.
What number is on the original BSM, I might have one....
x 6945
Harlequin wrote: 24 Sep 2019, 11:40 Part number was 6500CK - its the same part number for every facelift C5 (got it from service citroen). However the numbers on the side are different.
It's why I doubted it was 6500CK in reality - yes they are all the same across the C5 MK II - I know that, but on the second hand market essential to use the '96***' code.
Harlequin
x 23
Unread post by Harlequin »
9657718580 is the number on the side of the BSM in car. How do i `jump a 12v supply direct to the fuel pump`?
Can a BSM be reprogrammed and if so how?
Simon
411514
(Donor 2017)
x 39
Unread post by 411514 »
Harlequin wrote: 24 Sep 2019, 14:07 9657718580 is the number on the side of the BSM in car.
This number needs to be matched exactly - forget the Citroen part number, it covers many variants.
Harlequin wrote: 24 Sep 2019, 14:07 How do i `jump a 12v supply direct to the fuel pump`?
Just run a wire direct from battery to pump plug (accessed via hatch under rear seat squab).
Harlequin wrote: 24 Sep 2019, 14:07 Can a BSM be reprogrammed and if so how?
Probably, in the same way that Everest can be climbed, but too much like hard work for me, just find one with matching numbers.
Sam
2003 C5 2.0HDI 110
x 6945
If buying new - 6500CK is the only part you need form Citroen - there is no programming the module for your vehicle or an option of a pre-configured variant - there is only one part. Your issue is probably that a second hand seller has mis-sold it and it's not a 6500CK unit in the first place. I bought one of these for my MK II and no issues.
Harlequin
x 23
The par number on the unit i bought is :
9656086180
and was told it came out of a C5 as well.
Simon
Harlequin
x 23
its also physically identical to the one in my own c5
Simon
x 6945
Harlequin wrote: 24 Sep 2019, 17:33 The par number on the unit i bought is :
9656086180
That's your problem then - it's not correct - that one is 6500CG and typically from a Peugeot 407 and is an L02-00.
The look is irrelevant - they all look mostly the same - it's the electronic cards inside that are different - designed for different vehicle systems.
Harlequin
x 23
Thank you! I emailed the seller and they are adamant it is from a 2006 1.6 HDi citroen C5.
Simon
Doo
(Donor 2022)
x 121
Unread post by Doo »
I was looking for an under bonnet fuse box too and we found one that matched all the numbers identical.
It was installed and we still had our problem.
I already knew there were "almost" identical fuse boxes, but inside the electronics are routed differently to suit different requirements so I was lucky to happen across the right one.
Anyway, now waiting on a Lexia to see if I can interrogate the system and find why the ABS and associated systems are flagging up a fault which I can't trace :roll:
Has anyone seen the plot? :?
petef
x 11
Unread post by petef »
Getting the right BSM can be a minefield, I bought two before I got the right one for the C4. If it says 9657718580 on the side then that is what you need and nothing else will do.
Unfortunately this is one of the rarer variations but they do come up on ebay. If you want to take a punt there is a Polish site listing one at under £100 :
https://www.franceauto.pl/pl/p/MODUL-BS ... 004-K/2581
Installing the right one on the C4 cured all the original problems and the wipers could still be turned off.....!
x 6945
Eurocarcare have 9 in stock £162 inc. VAT:
https://www.eurocarcare.net/bulbs-fuses ... e-box.html
Harlequin
x 23
I would like to thank everyone - having previously used
viewtopic.php?t=49329
that thread and the opinion from it that any BSM will do ; i have today learnt it has to be identical.
Thank you for links - i have sourced one.
My C5 V6 petrol is alive again!
Simon
x 6945
Thanks for posting the thread link - I will review it with a view to moderating anything in it factually incorrect.
I'm pleased you sorted it.
x 3296
Yay, she lives again!
