Yes, that's why I can't help you, because the part numbers are for different switch blocks depending on the equipment and finish. If your X7 was originally fitted with SMEG, then of course the VIN would only show the correct part. But as your car had none of this, I have had to show all the possible part numbers for the different switch blocks.
The only exception is item (7) which has the same part number.
So to get the correct Block, you will have to look at the diagrams and work out which one you need according to your equipment.
C5 X7 Wiring diagrams
- x 6945
Re: C5 X7 Wiring diagrams
Georgios
Good morning and happy weekend everyone
Mark, I contacted the Spanish site Hydractives with the user there who had installed the specific button.
His reply was "Hello,
The button is not there, I bought one from Citroen and at a workshop they erased the drawings it had, they painted the drawings I wanted."
So nothing is as it seems. I'm getting old and learned-Haha.
Thanks again.
Thanks again.
Poloc5
Bonsoir a tous . Est ce que quelqu'un porrais me conseiller par rapport a un probleme que j ai sur une c5 tourer 2l hdi de 2011 163 cv. On m avait dis que les injecteurs n etaient plus ok, donc j ai achete trois reconditionés la voiture á démarré mais j ai l injecteur 3 que ne s'ouvre pas. Est ce que quelqu'un aurais le schema electrique du systeme d injection jusqu au boutier électronique pour que que controle le cablage pour voir si les fils il ne sont pas coupé qq part. Merci et bonne soirée
- x 5672
Please post in English!
Your enquiry translated with DeepL
Good evening, everyone. Could anyone advise me on a problem I'm having with a 2011 C5 Tourer 2L HDI 163 hp? I was told that the injectors were no longer working, so I bought three reconditioned ones. The car started, but injector 3 won't open. Does anyone have the wiring diagram for the injection system up to the electronic connector so that I can check the wiring to see if the wires are cut anywhere? Thank you and have a good evening.
Translated with DeepL.com (free version)
Poloc5
Hello everyone. Could someone help me with a problem I'm having with my 2011 Citroën C5 Tourer 2.0 HDI 163 hp? I was told the injectors were faulty, so I bought three reconditioned ones. The car starts, but injector number 3 isn't opening. Does anyone have the wiring diagram for the injection system up to the electronic connector? I'd like to check the wiring to see if any wires are broken. Thanks in advance and have a good evening.
PaulC5
- x 692
Which 3 injectors did you replace noting that they are numbered from the gear box end ?
