Diagbox Lexia 3, Graphic functionality not available.
x 6956
Re: Diagbox Lexia 3, Graphic functionality not available.
Hi Bob, I was quite busy on a low of other forum stuff, so I just assumed they were both estates without checking😀
As long as you fit the right ECU to the Saloon or Estate, it you have both the part numbers. It may be cheaper to get a second hand ECU which should be configured ok and see if that fixes your issue.
Bob_V
x 3
Unread post by Bob_V »
Marc.
My thoughts exactly. The hunt is on.
Bob.
Bob_V
x 3
Marc.
I've had a search around for a used Parking ECU. Prices range from £85 to over £190 and there are not many about, mainly in Europe. Cost of a new ECU is £231.66 plus VAT and they are on 'Back Order'. Finally tried the main dealer for a price to re-program my ECU. £40.00 including VAT!!!! It's got to be worth the risk. Trouble is they are busy and won't be able to do it for a couple of weeks. Watch this space.
Bob.
x 6956
Yes, that's about right - it's only a connect up to their servers and download the ECU configuration (that you would normally do via Lexia manually) - so shouldn't take the long and 30 mins top. It's what I suggested earlier I think - and if that cured it then you could proceed with the other car when it's back on the orad.
Best of luck Bob, let us know how you get on with it.
Bob_V
x 3
Marc.
Took Red Hatchback to the Main Dealers this morning. They said that the Parking ECU Software was up to date so they downloaded the configuration file from the Citroen Servers. Problem with the Front Parking Sensors now FIXED!!!! That's a relief. I will take the Blue Estate to them for the same treatment as soon as it is on the road.
All I have to do now is firstly remember not to go near the Parking ECU with my Lexia and secondly try to find a way of getting the Graphic Functionality feature to work as I may need it to track down a possible turbo problem.
Do you think that this problem with the Front Parking Sensors should be high-lighted as a separate topic rather than under the heading of Graphic Functionality?
Thanks again Marc for your help in this investigation.
Bob.
x 6956
No problems Bob. and I'm pleased that this has resolved the issue, excellent result.
Yes I think it would certainly benefit having a separate topic - even for a warning on the MK II C5 for others. I'll have a look and extract the relevant parking ECU bits and leave the graphic functionality posts in this thread, if ok with you.
Bob_V
x 3
Marc.
Fine by me to split the posting.
I'm not sure which C5s the problem exists on but as far as I know Front Parking Sensors were only fitted as standard on 'Exclusive' trim models. As you know I currently have two C5 MKII Exclusive cars both with Front and Rear Parking Sensors as standard. I also had a C5 MKI V6 Exclusive which also had the same set up. I have not yet had a C5 X7 so cannot comment on that variant.
Having now found a cure for the problem do you think it wise for me to stay on Diagbox 7.62 or should I now revert back to version 7.57?
Bob.
x 6956
It's ok Bob, I know which ones had which, I have an X7 with the similar system and also had it on my previous C5 the same as yours, but never any issues with the X7 - probably because it is an updated set up with parking space gap measurement too.
I'll split the posts shortly. As far as Diagbox goes, I would see how you get on for now and leave it at this version - but if you have any issues, revert it down back to 7.58.
Bob_V
x 3
Having solved the parking sensor problem, I thought I would try to find out why the Diagbox Graphic Functionality was not working on my laptop.
I changed video drivers, altered screen resolution etc. without success. I then read somewhere that someone else had this problem with Windows 7 but not with Windows XP. So, time to bite the bullet. I replaced the disk drive in my laptop with a known working alternative and installed Windows XP Pro on the replacement hard drive. I then installed all the updates I could find followed by Diagbox up to version 7.57. All seemed in order so, today, I tried it out on the car. I now have a fully functional diagbox complete with Graphic Functionality. So, it is fine on Windows XP but not on Windows 7.
Problem finally solved. The laptop I am using is a Sony Vaio VGN FZ18E with Nvidia graphics. I suspect that the problem is with the Nvidia graphics driver but don't have the time or inclination to pursue it further.
Bob.
x 6956
Ok, thanks for the update - I use mine on Windows 7 and have graphical data functionality - so must be a specific driver issue as you have found.
