Rust inside engine bay
dave_xsara
(Donor 2021)
x 10
Re: Rust inside engine bay
Unread post by dave_xsara »
myglaren wrote: 15 Oct 2019, 22:14 Photo not available.
You can upload direct to the forum:
https://www.frenchcarforum.co.uk/forum/ ... hp?t=56796
It should have been a video. I'll try again tomorrow. The uploader want recognising it. Note sure if it was file type or size was the problem
dave_xsara
(Donor 2021)
x 10
doctle wrote: 15 Oct 2019, 22:57 Maybe a silly question but are your front wheels balanced?
Not a notion. They are not wearing unevenly and I feel nothing through the steering.
dave_xsara
(Donor 2021)
x 10
dave_xsara
(Donor 2021)
x 10
Just realised you need to turn on the sound to hear the noise!
But the link should be working now.
I would have thought that they all do this?
doctle
x 225
Unread post by doctle »
It's quite difficult to work out what the problem is without having the car in front of you. Things like shock mount bushes and bearings can create vibration as can worn drop links, anti roll bar bushes and worn inner tie rods. For a cheap test secure the air box with a bungee cord if the vibration is gone job done.
Oh buggle
dave_xsara
(Donor 2021)
x 10
Job done and that rattle is cured. Bend the tangs back and also put a dollop of silicon sealant on the bracket too in order to provide a bit of cushioning. New gearbox mount too in.
Vibration still there :roll:
Running out of things to replace, but it has definitely become a lot less frequent now.
Yet another half resolved task to add to the pile.
dave_xsara
(Donor 2021)
x 10
I have possibly found the source of the vibration (or another problem...).
The front grill is loose and vibrates at idle. It was originally held on with a cable tie due to a broken tab, but I got some strong glue and it resolved the problem, but the retaining nut must have loosened or the tab broke again.
