Delayed retirement.. again. A conversion...
furriegurrie
x 40
Re: Delayed retirement.. again. A conversion...
Unread post by furriegurrie »
It sure does look like a crack, I wondered about that too!
x 1746
citroenxm wrote:no chris.. A bit of crap....
I hope you're right.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Looking again chris., I do NOT think Im right, it looks it to me too.... hmmmmm...
A very sad...
1994 XM 2.1 d auto
x 1746
Is the box still off? Thank goodness it's been spotted now.
citroenxm
Fallen Hero
x 70
Oh yes, ive not rushed that quick, I need to order a crank seal before it goes back together.... now I know theres no endfloat!
A very sad...
1994 XM 2.1 d auto
x 2938
I've seen a mark like that before, when a mechanic had used a cold steel chisel to split the worn starter ring off.
mickeymoon
Unread post by mickeymoon »
Surely that's a crack? The line of the flywheel is out too.
citroenxm
Fallen Hero
x 70
Yup, it is.. WELL SPOTTED guys, but damm well annoying! If its not one thing its another!!
CHEERS !!
A very sad...
1994 XM 2.1 d auto
x 1746
The starter teeth (presume those on the right) look damaged at that point, too.
x 3296
Think of it this way. If it HADN'T been spotted, and you had put it all back together, how long would it be before it started causing problems again?
citroenxm
Fallen Hero
x 70
Absolutley James, I completely appriciate the spotting of the said offender..
A very sad...
1994 XM 2.1 d auto
x 3296
Maybe that damage is what caused the flywheel to start scraping on the block.
citroenxm
Fallen Hero
x 70
James the car was an Auto... This is a Manual Gearbox flywheel that was bought and sent with the manual box thats going in! It was only wrapped in black parcel wrap.. It was the Auto box "flywheel" that has damaged the block. There is ZERO contact between this one and the engine.. (See previous Posts)
A very sad...
1994 XM 2.1 d auto
x 3296
Oops, sorry, my mistake.
x 1746
It takes a bit to crack a flywheel.
Ignoring a freak occurrence like contact with a sledgehammer, or being caught between the bascules of Tower Bridge, what could cause that?
One possibility: Engines often come to a stop, when switched off, in exactly the same rotational position. It used to be the cause of severe wear at one place on the starter ring, before pre-engaged starters took over.
In the case of the photo above, with damage on both the starter ring and on the timing-pulse teeth opposite, it looks as if the starter pinion might have overshot, with considerable force, and whacked that big block tooth to the left. The force available from a starter motor is massive. Maybe a starter motor badly fitted, or a wrong/substandard replacement. Maybe.
Even some tw*t with a crowbar might succeed in chipping off a tooth, but to split that thickness of steel? Whatever did it, it must have been clouted with some force.
Might be one for metallurgist John?
