urgent advice needed
Mandrake
x 695
Re: urgent advice needed
Unread post by Mandrake »
GiveMeABreak wrote:Simon - interesting - but when I print out the diagrams - I use the built in print feature of SEDRE (where the zooming controls are) - I never use screen shots. This then prints to whatever printer I want - but in this case I use CutePDF as my PDF writer. However, looking at one of the Preheating Ignition document - it does look very blurry - compared to the others!
This won't create a vectorised PDF, it will still be a bitmap. This is an Internet Explorer limitation not CutePDF. (I think from memory CutePDF with Google Chrome gives good results too, but why use CutePDF when Chrome has a built in PDF print exporter and from memory the result is a bit better)
Looking at your conversion - very crisp and easy to read - I'll certainly bear that in mind for future, cheers.
Another issue though - trouble is I can't use Chrome with SEDRE - Google have stopped all support for JAVA in Chrome from Sept 2015 I believe - so I can't even open any SEDRE pages with that browser now. So it's IE 9 for compatibility!
You don't use Chrome as a browser to browse Sedre - use Sedre with internet explorer as normal, locate the diagram you want, then right click the SVG image and save the SVG as a file. (SVG not SVGZ) Now open the saved SVG in Chrome and use print to PDF.
A lot of steps, but it's worth it as the result is perfect quality.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 6956
Great will give that a go next time I'm sending out electronic spaghetti!
RPWC
x 21
Unread post by RPWC »
been looking at second hand ECUs on eBay, the numbers are the same,part from bottom left, mine is 106963IWG, the ones on the bay are ending in FWG,with different numbers, is th is just the individual serial number for the E C U,as all the other numbers match up? I know I will need the get the ecu coded to the vehicle, that's if it's cattle trucked. I s
Cheers Rich :wink:
RPWC
x 21
Van sorted!!, Mark the spark came over tested all fuses with a heavy duty tester,found poor contact on fuse,removed ,checked the fuse socket,found slight corrosion, cleaned it ,replaced fuse, van started first time. :-D :-D :-D , so much for AA and my tests. At least I can work tomorrow now, thanks to all who offered advice and help, in the end it just needed someone with the right knowledge and experience.
Cheers Rich :wink:
x 6956
Sometimes it is the smallest and simplest things! Glad you have sorted it Rich.
