Brakes
daviemck2006
- x 485
Re: Brakes
He gave me discs along with the car, and the ones on it are quite pitted. I wonder if he maybe got discs and gave up trying to fit them as the bolts wouldn't move? I will however get bolts, just in case I do break any. One garage I asked about doing the discs on my first c5 said get new callipers and bolts too cos if they are seized on we will take them off with a grinder! Does the xantia suffer from the corrosion between calliper and trailing arm also? I seem to remember reading that it didnt
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 3296
Re: Brakes
The Xantia definitely DOES suffer from that weird corrosion between the radius arm and callipers, although (due to the lack of thread lock) it is not so difficult to remove the callipers. I would suggest you get replacement bolts, as if you have them you almost certainly won't need them (but if you don't have them, guess what?!?).
http://www.frenchcarforum.co.uk/forum/v ... =3&t=38467
My first posting on the FCF!
daviemck2006
- x 485
Re: RE: Re: Brakes
That's always the case! Sods law! Or I could use a few more inappropriate words [emoji12] [emoji23]Hell Razor5543 wrote:The Xantia definitely DOES suffer from that weird corrosion between the radius arm and callipers, although (due to the lack of thread lock) it is not so difficult to remove the callipers. I would suggest you get replacement bolts, as if you have them you almost certainly won't need them (but if you don't have them, guess what?!?).
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 8411
Re: Brakes
Davie, this is a another good thread on removal of caliper bolts:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=30007
lexi
- x 133
Re: Brakes
Thanks for tidy up Jim.......<facepalm>
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 5672
Re: Brakes
I was told the same when the first C5 went in for new discs. They did manage to do it without resorting to grinders and new calipers though.daviemck2006 wrote:One garage I asked about doing the discs on my first c5 said get new callipers and bolts too cos if they are seized on we will take them off with a grinder! Does the xantia suffer from the corrosion between calliper and trailing arm also? I seem to remember reading that it didnt
