Picasso fan problem please help
x 1955
Re: Picasso fan problem please help
Unread post by Paul-R »
It sounds as if it really did overheat then. I would guess that it was caused by an air lock or air bubble which has since been bled away.
Why the fan didn't come I don't know; you've checked that it and the resistors work separately but you now need a Lexia or Diagbox to check that the ECU can control the fan and set it spinning and this has to be your next step. Apologies if you've already done this and I've missed it.
As has been said earlier, at this time of year the fan is seldom needed anyway and if there's any problem with the A/C to prevent it turning on then that won't bring the fan on either.
x 6950
Paul-R wrote: ... and if there's any problem with the A/C to prevent it turning on then that won't bring the fan on either.
As I said previously. He already mentioned that the Air con is not working, hence my suggestion to get is gassed up and then turn the AC on - which should switch the fan on. :wink:
x 1955
Yes, my point was that there's nothing else to bring the fans on at this time of year.
Gassing up might be enough to get the A/C working and then test the fan that way but what if it isn't? That'd be £40 odd that, while not exactly wasted, would have been unnecessary. As I said, Lexia or Diagbox.
x 6950
Agreed - the fan would not normally kick in until about 185° F - so unless it's in crawling traffic on a hot day very unlikely the fan would kick in.
If the Air Con is gassed up and the fan does not kick in straight away or shortly thereafter, then we need to keep looking. As stated a diagnostic is a good place to start - I doubt this video will help - as we know your fan is working when you disconnect the temp sensor - but this is where the resistors are located on a 2001 Picasso and here the bottom one was registering no Ohms on the multimetre.
nomis1981
Unread post by nomis1981 »
Thanks for your help guys Gonna get air con gassed soon got it booked in for Friday next week at kwik fit.
my cousin has a lexia I've asked him if he could put it on he can't do it till next weekend not a problem as car drives great
Thanks again and sorry if this has caused any tension
x 6950
No problems and no tension - as you can see there are multiple possibilities, which is why we usually recommend a Lexia diagnostic first, to help eliminate some possibilities. Let us know how it goes - as I say, I'm not sure Kwik Fit charge if they can't get is cooler - ATS did the same with me once - they said it was fine so didn't charge me - not that they advertised it! At the very least you could have your air con working again!
nomis1981
Yeah kwik fit say if they can't get it cooler or working then there's no charge I won't take to ats as used to work for them and their dodgy ways and I know someone in kwik fit so may get a discount lol
I'll let you know the outcome when done next weekend thanks again
x 6950
I've just been out to check both our C5 and C3 that have not been started since yesterday and can confirm that as soon as the Air Con is switched on - the fan engages immediately on both cars. When I switch off the Air Con, after 2-3 minutes the fan stops on both too. On some cars there were 2 fans one for the air conditioning condenser radiator and one for the main engine rad. these were operated independently as needed - but on a lot of more modern cars there is only one larger fan to cover both. Anyway let's see what happens :-D
nomis1981
Yeah there's only one fan that covers both air con and cooling I know the fan works but I've managed to get some new resistors anyway as when I took one out it had plastic melted on it I got them both for £15 going to rip bumper off again in morning and fit them
x 6950
Sounds like a plan.
nomis1981
hi guys i took my car to my cousins to put on the lexia everything to do with the fan seemed to work fine he checked the fan with the dynostic and it kicked in at all speeds but the code p0340 came up pointing to the camshaft sensor it had another code but that went when we wiped them only p0340 came back what im asking is do i need to change the sensor or could i try cleaning
also ive changed the expansion tank and cleaned all the pipes that go to it one was blocked ive also cleaned the water sensor thats in front of bottle now the car runs great never misses a beat even with that code
