Peugeot 306 keys
mixalis kal
- x 23
Re: Peugeot 306 keys
You are absolutely right
I heard that if I disconnect my battery and connect the two cables together my ECU will restart..is it true?
spider
- x 77
That really only works for newer cars with a BSI and then only if you have trouble with it.
Andy.
mixalis kal
- x 23
Thanks.. Is it possible to connect a two button remote control for newer models with my phase 1 car?
spider
- x 77
I did mention this earlier in the topic
Yes and no. It would be possible but I don't know how difficult it would be to do. The 'easy' way would be to replace the roof receiver, the 'control box' (under front seat or under back seat area varies on model) and the key transmitter.
The difficult way would mean some of the loom would need changing as well as possibly the door actuators too (unlikely) as 'two button' models, 90% of them have deadlocks.
Andy.
mixalis kal
- x 23
Thanks for the information!! Yesterday my battery went dead so I started with cables. Suddenly the problem with the keypad gone. I will try again later but I hope to be OK.
Also I found this :
and I am thinking to try it. At comments mine are these with Peugeot 306 username.is the big wire connector behind the left headlights as in 106 . Thanks again!
Also I found this :
spider
- x 77
That's called the IC1 connector. 306's have them too but they are around the battery area, same big round connector (might have two) , I think I mentioned this before not sure.mixalis kal wrote:Thanks for the information!! Yesterday my battery went dead so I started with cables. Suddenly the problem with the keypad gone. I will try again later but I hope to be ok. Also I found this and I am thinking to try it. At comments mine are these with Peugeot 306 username.is the big wire connector behind the left headlights as in 106 . Thanks again!
Your IC1 (called something else) is near the battery / inner wing area.
Andy.
mixalis kal
- x 23
Thanks again!!!
Do you think that is a good idea to check if is everything ok with the connection?
spider
- x 77
Yes if you can.mixalis kal wrote:Thanks again!!!
Be careful if you unscrew it as the plastic can crack a bit if its old. There is a sort of 'ring' in the middle of it you turn to 'undo' the connector itself.
Ensure that ignition is *off* (keys out!) before undoing it.
Andy.
mixalis kal
- x 23
I think that I found it. I didn't unscrew it . I tryied to turn it a bit and I pushed in the cables. After that my keypad works fine. I will try it tomorrow again to be sure. If I could I would send you pictures of the cables I pushed!
spider
- x 77
Its probably corrosion inside it then or it was a bit of dirt. If you do take it apart to clean it, please do *not* use WD40 on it. Use contact cleaner or a gentle solvent (check plastics are OK!) as WD can over time (so I'm told) change slightly so it may not work as well as it appears.mixalis kal wrote:I think that I found it. I didn't unscrew it . I tryied to turn it a bit and I pushed in the cables. After that my keypad works fine. I will try it tomorrow again to be sure. If I could I would send you pictures of the cables I pushed!
Regarding images, I cannot use Photobucket anymore as my ISP is a bit poor. You can just quickly upload to imgur.com and then link here via the IMG tag.
Andy.
mixalis kal
- x 23
I turned this which is down and right as you see the picture and you can see some cables . Is it the right fuse or I did a mistake?
spider
- x 77
Andy.
mixalis kal
- x 23
If you meant the fattest which is down, you mean that I pushed! Is there and second? Where is it?
spider
- x 77
That is all there is usually. If there are not more there then that is it.mixalis kal wrote:If you meant the fattest which is down, you mean that I pushed! Is there and second? Where is it?
Andy.
mixalis kal
- x 23
Hello,
I am going to buy an anti theft system and I am between Autolok 2000 and disclock. What is the best for you?
Thank you !
Thank you !
