2002 2.2 Auto C5 - Lots Of Odd Problems?
lexi
x 133
Re: 2002 2.2 Auto C5 - Lots Of Odd Problems?
Unread post by lexi »
Just keep it below 60 and potter on then. That will buy you time to get other stuff sorted and then come back to your limp mode issue.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 2008
Unread post by Stickyfinger »
Without a Lexia you will / we will just be guessing all the time.............if your going to stick with this car you need a readout or drop £150 and get a Lexia.
Do not start on anything connected with the electric with an unknown battery in the car (even if it does start)....again that will just mess up everything.
waynedance
x 8
Unread post by waynedance »
Glad you decided to keep the C5, pitty its been neglected.
Hope you get it all sorted.
Sent from my LG-H815 using Tapatalk
Volvo S80 D5.........
wurlycorner
x 271
Unread post by wurlycorner »
What is this dreaded low voltage problem? (not heard of it)
Iain
CX DTR T2 Safari (silver)
waynedance
x 8
Look at getting battery tested, a poor battery can cause all sorts of electrical problems.
x 3298
The C series of Citroen cars are very sensitive to failing batteries, as they have a lot of electronics. There have been numerous occasions when a new battery has resolved strange, seemingly unrelated problems.
wurlycorner
x 271
Ah that, ok thanks.
Sounded like something altogether more sinister!
Iain
Monkeyfeet
(Donor 2022)
Unread post by Monkeyfeet »
Just back to the sluggishness below 2250rpm for a mo' - Did you checked the condition of the MAF at all? It's easy to get to, it might be worth taking ten minutes to spray it clean (carb cleaner etc). It's an issue that sometimes comes up with K&N etc oiled filters, some of the oil gets onto the sensors, which they don't seem to like much. Worth taking another look at the filter too.
(If you do this be very, very careful not to actually touch the sensors, they're sensitive and brittle)
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
