stopped for 5 min. temp gauge in red..................
john
Re: stopped for 5 min. temp gauge in red..................
if an engine is idling for 10-15 and the air being blown out of the vents is hot should the thermostat be open to allow the water to be run through the rad?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
LeWaftBarge
I'm not so hot on this subject, but the thermostat opens and closes to allow coolant to circulate the engine channelways once it has reached a certain temperature. Normally the heater is controlled by a separate valve.
Are you getting any warm air whilst the car is up to temperature? If not, you could have an airlock in the cooling system.
john
yes it blows out hot air but the rad is still cold, thinking the thermostat may have gone.LeWaftBarge wrote:Are you getting any warm air whilst the car is up to temperature? If not, you could have an airlock in the cooling system.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Ben82
- x 7
On my C5 the thermostat was stuck open, and the car would not blow out hot air. The car would moan it was overheating even though it was -10 to -20c outside at the time and the car had only been running for about 5minutes.
If the Berlingo works in the same way I would say the thermostat would be an unlikely culprit. Stuck open would mean the engine would take a lot longer to get upto temperature and not give hot air out the vents. Stuck closed would mean its overheat and you would not get hot air through the vents.
If it was stuck partially open then maybe.
But either way getting it on a Lexia should help reveal what's going on.
2004 Citroen C5 3L V6 Auto
Brit living in Sweden with an imported from Germany French Car!
Stewart(oily)
- x 35
Few modern cars have a water valve type heater, the circuit with the thermostat closed circulates water through the heater matrix and the block all of the time, if the heater controls are off then flaps keep the warm air away from you, once the pre determined temp has been reached the thermostat opens and allows water to circulate through the radiator, the thermostat can operate partially open too, and although designed to fail in the open position it is not unheard of for them to stick closed.
Northern_Mike
This sounds like a blocked rad and/or broken fan. It doesn't sound like a head gasket failure. When I've had HG failures in cars, including a 1.4 ZX with this motor, they overheated on the move under power, not when stationary. My Capri with it's knackered viscous fan (which I replaced with a kenlowe) and the Saab with a blocked rad both overheated when ticking over when there was no airflow to cool them down.
john
no one near me with 1 though.Ben82 wrote:But either way getting it on a Lexia should help reveal what's going on.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
LeWaftBarge
Admittedly I'm going from experience of a 2001 Ford Fiesta....hardly a pinnacle of modern engineering!Stewart(oily) wrote:Few modern cars have a water valve type heater, the circuit with the thermostat closed circulates water through the heater matrix and the block all of the time, if the heater controls are off then flaps keep the warm air away from you, once the pre determined temp has been reached the thermostat opens and allows water to circulate through the radiator, the thermostat can operate partially open too, and although designed to fail in the open position it is not unheard of for them to stick closed.
addo
- Sara Watson's Stalker
- x 95
Mandrake
- x 695
John I'm in Coatbridge and have one, and there is at least one active member in Fife with a Lexia, although I don't recall who off the top of my head, I know because I was going to contact him before I had a Lexia of my own...john wrote:no one near me with 1 though.Ben82 wrote:But either way getting it on a Lexia should help reveal what's going on.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
john
couldn't see anyone in Fife on the map.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
Estately
- x 22
John,
You don’t say if you have removed and inspected the thermostat.
The one fitted to our 2000 90Bhp Xantia operates in two ways. One part of the stat opens to allow circulation through the heater matrix and engine, the other (lower) part opens to allow circulation to the radiator as well. If the second part has failed then you will find that the heater is getting warm whilst the top hose will be cold and the engine will overheat when stationary.
Andy.
Andy.
If it can happen it will.
john
i checked it this morning, it seems ok, i removed top hose (expecting it to be full of water) and there was some water but i wasn't full.Estately wrote:John,
Andy.
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
addo
- x 95
LeWaftBarge
This may have been asked but is the water pump okay?
