Crappy Climate control and stupid hydractive
Harlequin
x 24
Re: Crappy Climate control and stupid hydractive
Unread post by Harlequin »
save it being weighed in - throw it at me :D
Simon
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
i repeat... i DO NOT weigh things in.. i useually fix them.. just i dont have the time messing with my own.. cheers guys... will see if i get time to do anything. but the answer i think is a set of softies.. or drill the centre holes out on the hydractive spheres.....
A very sad...
1994 XM 2.1 d auto
Citroenmad
x 110
Unread post by Citroenmad »
If you know the spheres have the required amount of gas in them then you could turn them into comfort spheres by drilling the centre hole slightly. Though this plays with damping and can leave it rather underdamped. Its not the best way around things in my opinion, a Hydractive Xant can be made much softer but while keeping damping the same.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Xaccers
x 186
Unread post by Xaccers »
citroenxm wrote:BEFORE you all shout I know shes not in hard mode because when I do press the S+@!e button on the dash she does go harder..
Hang on everyone seems to have missed this bit.
Xantia sport mode doesn't put it into hard mode, so along an easy undulating road you won't notice the difference between sprot mode being on or off.
It could he ride height or the clamp on the end of the manual rod being in slightly the wrong place so changing spheres won't make a difference.
I'm due down to St Asaph (it's too small to be a city) probably at the end of the month or early May, could perhaps coincide with Jim's visit and come see you :)
DIY sphere tool
citroenxm
Fallen Hero
x 70
i disagree xac... when i do press the switch its very noticeable that she is a lot firmer permanetly...
im at x rally next weekend..you can all look and mess with her then and tell me what you think...
A very sad...
1994 XM 2.1 d auto
Xaccers
x 186
citroenxm wrote:i disagree xac... when i do press the switch its very noticeable that she is a lot firmer permanetly...
Definitely something wrong then, could be someone's wired the switch up to the fuse so activating it pulls the fuse giving perm hard mode, like hydractive 1
DIY sphere tool
x 8284
Yes there is as in normal driving the only obvious effect of pressing the switch is lighting up the switch. All the switch does is tell the ECU to change the thresholds at which hard/soft switching occurs. In Sport mode the suspension switches hard mode more readily than it does in comfort mode.
Generally the switch from soft to hard occurs when cornering, braking and accelerating with some enthusiasm. If you watch live data from the ECU it is keen to switch when going around corners to give it some roll resistance. The switching between hard and soft you don't feel at all. You only know it's done the job because of the low (not as low as an Activa but much less than a standard Xantia) amount of roll the occurs when cornering.
