Opinions on tyres for Xantias?
Xaccers
- x 188
If memory serves, Michelin Energy 185/65 88H from Costco (for Cassy) are about £80
DIY sphere tool
DIY sphere tool
Citroenmad
- x 110
One thing i did like about them was their appearance, they have a good tread pattern and i like the fact that the sidewall is not like a baloon, its quite flush with the wheel rim. Or it was on this car. Actually a good tyre for hard and fast driving i thought, as the sidewalls were stiff they gave good feedback and the sidewalls didnt give under hard cornering.HDI wrote: I'm using the Verso on mine and will say again they are great and suit the Xantia very well. Actually I have found wet grip very good , in conditions where I was expecting to back off they just kept gripping.
The tyre place i use used to be a key dealer for Marangoni, so they could get them very cheaply, by far the cheapest tyre available from them at the time. Though i think they have moved onto supplying Maxxis or something.
I think the Vanto has now been replaced by the Verso.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
HDI
- x 7
Hmmm , hadn't even thought about that but as you mention it they do have a purposeful appearance !
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Citroenmad
- x 110
Yes, not a bad looking tyre really, replaced by the Verso which doesnt look quite as good but still has a stiff, flat sidewall.
How do you find wear rates, HDi?
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
HDI
- x 7
About average. Definitely much better than budget tyres which always wear out quickly on the inside shoulder. At one time I thought this was due to a tracking or geometry error on the car but a laser alignment check showed it to be spot on. Budget tyres just don't have the carcass strength of good tyres.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
rmunns
- x 9
rmunns
- x 9
As a matter of interest, I have found another site where you can put in the registration number and you are then given the original tyre size fitted when new.
This again says 205/60 x 15" 91 for my Hdi90.
Can I put such wheels on my car? I've got the offer of a set of exclusive alloys from a Xantia (year 2000 Hdi110).
addo
- Sara Watson's Stalker
- x 95
Check the alloys for type. It's written on the rim edge visible from under the car looking outwards.
Le Castellet (6J) are for 185/65/15. Magny-Cours (6½J) are for 205/60/15. Steelies (6½) fit the wider tyres, too.
Make sure to get the correct wheelnuts - I have found a good number of mine are showing cracked cupped spring washers, so new ones by wheel type is often the best practice. Check for suitable penetration through the wheel and also seat type (conical or flat). If the spare differs, be sure to carry nuts for it also.
Cheers, Adam.
Cheers, Adam.
rmunns
- x 9
addo
- x 95
Fair enough.
As related commentary, I yesterday put my 75% C-Drives (205/60/15) to the front and shod the rear with new Kumho Solus in the same size. These "follow" well and seem nicely weighted from the factory (they're yet to be balanced).
My personal belief is that since a Xantia (estate, particularly) is pretty nose heavy, it needs most of a tyre's natural grip at the rear; the front's weight is a good fortifier of worn tyres. Had I room for two spares, I'd actually run 185/65/15 to the rear.
