Citroenmad wrote:Im 100% sure they are the same, nothing like that was changed between S1 and 2. Just think of Activas, they use the exact same wheels for S1 and 2 cars.
They are 15" aren't they? some 96 cars had 14" wheels.
S2 Xantia's have a wider track than S1's (that's why S2's have the wider front wing's) and to that effect 15" wheels do vary, to identify you have the same wheels look at the cut-out's in the wheels, some are circles, others are triangular.
14" wheels were used on 18 petrols and IIRC 1.9D/SD models.
On the subject of tyres personally the only advice I'd take from others is from someone whom I know to be an proven expert (i.e. qualified) as when it comes to driving there are for too many who claim to know what they are doing behind the wheel when in reality the opposite is invariably the case. To correctly assess the ability of a tyre you need to be able to correctly balance a car on the approach to a turn then and continue the process through to the exit side which is a rarely seen skill in isolation, let alone find someone able to do it consistantly in order to make an accurate assessment/comparison.
Whenever I've seen the results of independant tyre tests, in almost every case budget brands have poorer grip with the consequence of longer emergency stopping distances,,,,,,,,,,,,,,,,,,,,,
