Bleeding activa...
KP
x 27
Unread post by KP »
Well i now finally have the pipe off...
Both seals at the end are very different.
One seems to be the citroen type.
The other is a normal brake pipe type flare.
Which one is right?? is it possible that both ends should be the same and the problem i have is that the pipe has snapped off in the HP Pump???
Or is this how it is meant to be??? The pipe is about 7mm in size so i guess i need to find somewhere now that makes it up locally as its much larger than normal brake caliper pipes i've seen in the past...
x 8406
Ask Gareth Will as he has his in bits at the moment and you and he can compare pipes although his being a late S2 may well be different.
The brake-type flare will be at the pump end and the Citroen end from the pressure regulator. There would have been a rubber seal with that end. I'd not think anything had broken. If you can fish out a rubber seal from the pressure regulator, you know that is right.
I'm a little surprised as I thought the majority of modern pressure regulators had brake-type flares for the inlet pipe although I know early ones did have the classic Citroen type. I'm not sure when they cahnged over as my '97 V6 has brake-type flares at both ends of that pipe. I'm not sure what my Activa ('96) has as I've not had reason to remove it and you can't see just by looking...
Yes, not standard at all and you'll have a bit of bother having one made locally in a normal garage/factors.
have you tried Martin (Pleiades)? He should be able to make you one, wind it up and pop it in the post to you...
KP
x 27
Unread post by KP »
Problem is if its wound up and posted does that not mean it wont fit correctly without me having to try and rebend it without bending tools???
I'll have to dig gareths number out and maybe give him a bell :)
x 8406
KP wrote:Problem is if its wound up and posted does that not mean it wont fit correctly without me having to try and rebend it without bending tools???
If Martin makes it out of Kunifer, it'll straighten out a treat if he rolls it in a biggish loop to start with and you'll find it easy enough to bend it to the shape of the old pipe. No worries there.
Gareth is about now. Try a quick PM..
KP
x 27
Unread post by KP »
Sorry guys but have been very ill with some bad bug going round and don't feel quite right even now, kidneys still killing for a start never mind the headache and gut ache :(
Anyway the car has had to be towed away as the new temp tennants next door have kicked up a big fuss and their landlord thinks its some H&S thing that i cant park in front of our grass on the shared driveway that is massive(as you know jim) so its sat at the folks in law who have kindly allowed me to keep it there until its repaired. still no news from citroen on the bolts for the pump or the control arm :( may have to get them off a scrapped activa if i can find one....
Ordered new pipe from Plaides, incase anyone needs to know i measured it at 1162mm in length. And it is meant to have normal DOT Flare one end and Citroen at the other end :) so fingers crossed it arrives tomorrow, if not next week sometime.
x 8406
Sorry to hear you've not been well Will :(
Some people are staggering in their pettyness :twisted: Yes, I know precisely where you mean and could not see any problem at all. Down here someone would use that space for a white van :roll: Just makes me realise what a good lot of neighbours I have. Sounds like yours need a lesson in the old principle of live and let live.
Pleased the new pipe is on order. Good old Martin :D
x 5673
Get well soon Will!
I agree with you and Jim, the amount of space there is there is amazing.
H&S problem - where would they get that from? Nimbys.
KP
x 27
Unread post by KP »
No pipe today, i guess it was hoping a bit much that 1st class would get it here on time but it will be sorted out next week im sure :)
KP
x 27
Unread post by KP »
Well its been fitted a while and testament to Plaides work is still going strong :)
Routing isn't perfect as i cant bend it just right but it will do for a long while :)
On another note....
The HP pump fitted to activas, is there an alterantive pump that is say 5+3 or 4+4 at all as this would make for much stronger suspension response and allow it to settle out more quickly on first startup??
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
KP wrote:On another note....
I don't think so as the 6 pistons are required for steering, one of the "delights" of Activa ownership, similar to my DS really, sitting there waiting for the suspension to rise :lol:
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Agreed! I might look like a right twit, but I just love sitting there while it gets up like a camel.
x 8406
Did your Activa not come with it's own copy of "War and Peace" Will?
They were standard issue, along with the handbook, to keep you occupied whilst you waited for hydraulic pressure to come up and put the STOP light out.
It still faintly amuses me just how long it takes. Strange as a normal Hydractive gets up to pressure very quickly.
DickieG
x 33
CitroJim wrote:They were standard issue, along with the handbook, to keep you occupied whilst you waited for hydraulic pressure to come up and put the STOP light out.
Remember that your "normal" Hydractive Xantia isn't when it comes to pumps as the V6 pump has a higher output than other "normal" Hydractive Xantia's, remember me mentioning some time ago about how much quicker my V6 rises compared with my HDi and TD?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
KP
x 27
Unread post by KP »
2 other thoughts then...
V6 pump onto an Activa??
Electric powered pump so that you could have it powered using the same kick in and out as the electrovalves a bit like a C5 or C6??
DickieG
x 33
KP wrote:2 other thoughts then...
Err not as simple as that as the V6 pump's higher output will blow the seals on the steering rack unless you want to change that (IIRC there's may well be an extra flow control valve there somewhere as well).
Not too sure how LHM and LHS are compatibility wise when it comes to rubber seals.
Its a lot easier being patient or getting out of bed one minute earlier :lol: :lol:
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
