The advantages of having a spare car or FEW spare parts lieing about!!
This 207k Xant I got has two methods of starting - if its AS SOON as the light goes out she WILL smoke for a few seconds... grey etc etc HOWEVER, if I leave the plugs a few more seconds AFTER the light goes out, say about another 10 seconds she starts AS GOOD AS 20k!!!!!!
Im happy with that, and wont bother dooing anything untill she gets HARD to start.. Why upset something thats working...
Paul
xantia 1.9td turbo change
citroenxm
- Fallen Hero
- x 70
boeingmech
Xaccers
- x 188
When Cassy is running on derv, if she stands idling for 5 maybe 10 minutes or more, there's black smoke when she pulls away (after 15 minutes there was a very large cloud of it!)
However on veg, she runs a lot quieter and smoother, and I don't recall seeing any black smoke.
These turbo threads always interest me as I'd rather catch a problem early than lose the turbo (as happened with Sophie, my Laguna II 1.9DCi after about 40K)
DIY sphere tool
DIY sphere tool
Deanxm
- x 87
What happens is at idle the exhaust gas flow is cooler and slower, the oil leaking from the turbo on the exhaust side runs in on idle but is not burnt, when you rev the engine the exhaust becomes hotter and the relativly large amount of oil is boiled off (White smoke) or is burnt off (blue smoke) depending on the amount of oil leaking.
If you take the car on a long run the exhaust stays hot and the oil is burnt as it leaks out in tiny amounts and so is not noticable, until you stop and idle for a while and so it starts again.
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Deanxm
- x 87
Black smoke is unburnt fuel.
I have run my transit and some Merc and DAF lorries on veg oil and they do run quieter and with less black smoke than when on derv, had to stop though when the diesel price dropped and it became financialy pointless to carry on running them on it.
D
D
XM Prestige PRV6 92
boeingmech
Deanxm, thats exactly what i thought hence my first question how easy is it to change the turbo, i was thinking of taking it off then i would possibly see oil on the exhaust side if it is leaking, but as i need the car for work i have nightmares when it comes to undoing nuts and bolts on the exhaust,they are bound to be rusted.
Deanxm
- x 87
Black smoke is lack of air or too much fuel, both are basicaly the same thing (too much fuel trying to be burnt with too little air) resulting in incomplete combustion.White smoke is fuel being burned in the exhaust system, you can't boil off oil.
Black smoke is a dirty injection and inlet system
and if you pour oil onto a hot surface and dont ignite it (by starving of air like in an exhaust system) you get large quantityies of white smoke.
D
XM Prestige PRV6 92
Deanxm
- x 87
The Turbo's are going to be a pain to get off purely because they are down the back of the engine.
I think you will need to have a look at the Haynes book of Jokes, not sure how well they cover this job on the Xant though and ive never done one in this car.
The problem comes when, as you do, the car is needed on a daily basis, but if you could get a loaner for a while all you would need to worry about is if the studs and nuts that hold the turbo on arent rusted into flakey brown ball's
D
D
XM Prestige PRV6 92
citroenxm
- Fallen Hero
- x 70
Dean,
As I said way above, removal is NOT that bad on the XUD, there is NO coolant pipes it disconnect, just oil feed, and it comes out MUCH easyer with the drivers side drive shaft out, and remove it WITH the manifold, theres just 6 nuts then but the studs need removing to make it easyer... by locking two nuts together on each stud to undo it....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
boeingmech
Brigsygtt
The classic symptoms of turbo failure are smoking on overrun, smoking on idle. Even the most knackered turbos don't smoke on acceleration/boost.
Check for play in the turbo shaft. There should be no more than 1-2mm in all directions.
If the turbo is shot you need to find out why it has failed, whether its lack of oil pressure, overboosting due to boost leaks, oil contamination etc. If you change it you don't want to do it again after a couple of thou miles.
Rough running & smoke on startup will not be turbo related imo. Id be looking at the injectors/fuelling. Ive blown a few turbo's up in my time
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
jgra1
- (Donor 2021)
- x 36
I did a 405 TD turbo change a few years ago
agree that upper engine mounting removal is a must
also, I used a scissor jack to help the engine away rom the bulkhead as far as it would go.. then removed inlet manifold and the turbo/ex manifold was easy from then on... I am not sure i ever went under the car.. cant remember..
Job was easy really, and should have taken about 2 hours... but I installed a new turbo unknowingly from an auto, and it was every so slightly different ( exhaust flange about an inch displaced, due to no gearbox linkage rods I think)
75000 does seem very low though..
John
John
boeingmech
just got home and thought i'd try this, engine nice and hot let it tick over for 5 mins and then floor it, big cloud of oily smoke out of the back end, let it tick over for a few secs then held it at 3000rpm got a cloud of smoke then it cleared whilst still holding the revs, let it tick over then floor it got another big cloud of smoke
Deanxm
- x 87
I will admit im no pro but in my experiance it IS very possible that a turbo can fail in this way (i have just replaced one that failed in exactly this way) but, it will not as Brigsygtt has said cause rough running or smoking on start up unless the turbine shaft is jammed solid but you would definatly know if that had happened.
D
D
XM Prestige PRV6 92
