Fuel Filter housing compatibility XUD9TE
x 94
Unread post by citronut »
i find the kit for leakoff tubing wich is a length of cloth bound rubber tube the best,it comes on a shrink rap card as a one lenght of tube youcut to the lenght you require also in the kit are two end caps,very cheap,and it just pushes on quite tight fit no clips required
regards malcolm
philhoward
Unread post by philhoward »
I found the Halfrauds kit fine - cured my problems with air (it does come with the end caps, and was £5.99 IIRC)
KP
x 27
Unread post by KP »
I got one from a local motor factors for £4 earlier as it was the only place i could get to before work and has coem with two very tiny mole grip type devices that i assume are the lock the end of some normal pipe. At teh minute the bung at the end of the rail is a screw into a short bit of pipe...
BonceChops
Unread post by BonceChops »
citronut wrote:vegy oil is sold at pumps now for running in cars,not many places sell it yet,there is one at RYE harbour,east sussex
regards malcolm
Are you sure you don't mean Biodiesel and not veg oil. There is a big difference.
Now Citrtoenless
x 94
sorry thats the one
regards malcolm
