x 6946
@Rhothgar:
Front Brakes
(1) OEM Front Discs, part: 4249J6, £93.65 (each)
Alternative PSA Cheaper part: 1686717080, £81.95 (each)
(3) OEM Front Disc Pad Kit, part: 1647862780, £125.00
Alternative PSA Cheaper Kit, part: 1617270080, £46.06
As for Previous Data for the rear:
Prices have gone up:
424946, £161.62
1619238880, £106.90
(2) OEM Rear Brake Pad kit, part: 1647873880, £87.14
Alternative PSA Cheaper Kit, part: 1617272680, £46.27
(7) Set Column Screw, part: 443936, £92.86 (Yes, not a typo! :shock: )
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
GiveMeABreak wrote: 16 Feb 2025, 11:29 (7) Set Column Screw, part: 443936, £92.86 (Yes, not a typo! :shock: )
I am sure the existing ones will be fine then...
Thanks for the info. Be just shy of a grand if she wants me to use the top spec OEM and had the Set Column Screws (assuming ones didn't need doing - and I am assuming same part number for the front)
Thanks again for your remarkable input into this forum (and parts requests especially) not forgetting RichardW.
x 6946
No, completely different for the front:
(6) Set Column Screw, part: 1648322080, £
I don't have the price at this moment, as they are undertaking maintenance / updates as they do on a Sunday, but expect it to be around the £70-80 mark minimum I expect. I'll confirm and update the post when I can.
Adam83
Unread post by Adam83 »
Hi could i please get part numbers for
New N/S Driveshaft
New O/S Driveshaft
For a 2017 Citroen Grand C4 Picasso
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thanks.
x 1496
Adam83 wrote: 17 Feb 2025, 16:22 Hi could i please get part numbers for
New N/S Driveshaft
New O/S Driveshaft
Thanks.
RH: 9677916180 New @ £536.23 / 1609609680 Exchange @ £321.95
LH: 9811176880 New @ £635.32 / 1613306580 Exchange @ £388.32
There is a £60.01 surcharge each for the old shaft (even if you buy an exchange one).
There is also an outstanding recall on this vehicle - you will get this done for free if you book it in at your local dealer:
HKT - Wiring harness
The operation involves checking the routing of a wiring harness in the engine compartmen and rectifying it if necessary.
HKT
17/12/2020
Adam83
Perfect Thankyou.
GavinPJ
Unread post by GavinPJ »
Oil leak from the vacuum pump sorted. I have a new leak now.
Can I get the diagram for the bottom of the block, might have to do crank bearings
too while that is open. :-(
Part numbers list if possible with the drawing. Thanks.
Gav.
x 6946
GavinPJ
Thanks Marc, is there a break down of the bottom of half of the engine block, sump etc.
x 6946
GavinPJ
Thanks a million Marc. Starting to regret getting rid of my C5.
Huskyxantia
x 921
Unread post by Huskyxantia »
Hi Marc, could i have part number for crankshaft oil seal my vin
VF3**************[VIN obfuscated, can be read by forum staff] many thanks,
:-D
x 1496
Front or rear?
GavinPJ
Morning lads,
Can I get the diagrams for any seals in or around the crankshaft (flywheel end) and any around
the flywheel or block etc. Want to see what is there before I pull it apart.
Thanks,
Gav.
completediv
Unread post by completediv »
Hi
Can you supply me with Part Number for Citroen C5 X7 Tourer 2010 Front Lower Suspension Arm Lower Hub Carrier Bush so I can source correct one on Ebay?
Thanks in advance
