Akul25
Unread post by Akul25 »
Hi I just need to know what cam housing part number is on these two Peugeot 308's 1.5 Bluehdi (Or even better, if you could tell me what cam chain these two cars would be factory fitted with, if either the old 7mm chain or the upgraded 8mm chain)
Thanks in advance!
VIN 1 - VR3**************[VIN obfuscated, can be read by forum staff]
Vin 2 - VR3**************[VIN obfuscated, can be read by forum staff]
stickery74
Unread post by stickery74 »
RichardW wrote: 23 Jan 2025, 19:55
stickery74 wrote: 19 Jan 2025, 18:57 Hi Marc, Could I get part numbers for a MAF meter/sensor and a Crankshaft Position sensor please.
VIN is VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff].
TIA, Rob
MAF - 1920LK £275.76
CPS 1920EH £ 83.48
Thanks Richard, can I ask where those prices are from? I'm struggling to find the parts.
Huskyxantia
x 901
Unread post by Huskyxantia »
VF3**************[VIN obfuscated, can be read by forum staff] 308cc
Please can I have part number(s) for complete timing belt kit Inc waterpump & pulleys , also the crank shaft pulley , harmonic? Thanks Marc
:-D
GavinPJ
Unread post by GavinPJ »
GiveMeABreak wrote: 29 Jan 2025, 12:03 Yes, just remember quality of aftermarket - so make sure you get a decent branded one if you can as you don't want to be replacing that every 2 minutes. PS Gavin can you update your profile on the left to reflect your 508 vehicle as the current one to avoid any confusion, thanks.
Got a Febi Bilstein one for €38 this morning. 10 mins will have it on this evening.
One more job complete. Now to sort the dodgy heater! -1 here this morning so
I took the C5 to work.
Jay-Bruce
x 280
Unread post by Jay-Bruce »
Hi guys, once again I'm thanking the deity's fir the existence of this forum, as I'm needing the part numbers and prices for the front height sensor brackets on our 3.0 V6 hdi C5 (X7) tourer... I have a horrible feeling they are going to officially be NLA, but with the part internet can turn the internet upside down to maybe find some NOS, or worst case the diagram will give me a starting point for Heath Robinsoning something up.
x 6956
Well you're half right Jay!
(3) Bracket (Left), part: 5273K9, No Longer Available (Was £12.00)
Bracket (Right), part: 5273L0, £12.95
x 6956
stickery74 wrote: 30 Jan 2025, 07:35 Thanks Richard, can I ask where those prices are from? I'm struggling to find the parts.
These are official Citroen part numbers with official Citroen retail prices, so you can get them direct from your dealership or search for alternatives using Google.
E.g. MAF:
https://www.autodoc.co.uk/car-parts/oem/1920lk
CPS:
https://www.google.com/search?q=1920EH& ... e&ie=UTF-8
x 6956
Akul25 wrote: 29 Jan 2025, 18:23 Hi I just need to know what cam housing part number is on these two Peugeot 308's 1.5 Bluehdi (Or even better, if you could tell me what cam chain these two cars would be factory fitted with, if either the old 7mm chain or the upgraded 8mm chain)
Thanks in advance!
VIN 1 = 7mm Cam Chain
VIN 2 = 8mm Cam Chain
It's only late 2023 models on that will have had the 8mm chain and associated parts fitted at factory.
Your first one is too early being an early 2023 model and Euro 6.3. The second one is late 2023 and a Euro 6.4.
x 6956
Huskyxantia wrote: 30 Jan 2025, 08:01 VF3**************[VIN obfuscated, can be read by forum staff] 308cc
They don't have the full kit with the water pump shown for this model, only the distribution kit for the pulleys and belt:
(6) Distribution Kit, part: 1608747480, £188.23
Water Pump Options
(1) OEM Coolant Pump, part: 1684447980, £118.91
Cheaper Alternative, part: 1623095180, £73.76
Huskyxantia
x 901
Thanks Marc, are all the water pumps now plastic propeller or can you get the metal types aswell ?
:-D
Stijn
x 3
Unread post by Stijn »
GiveMeABreak wrote: 13 Jan 2025, 16:14
Stijn wrote: 13 Jan 2025, 05:39 I need the part number of the thermostat for VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
(1) Engine Outlet Water Tank, part: 9803648780, £205.88
(2) Water Temperature Sensor, part: 1338C1, £70.18
Hi Mark;
Is there part number for the "engine outlet water tank" gasket? Number 5 on the picture?
x 6956
Yes, (5) Engine Water Housing Seal, part: 134099, £4.98
Jay-Bruce
x 280
GiveMeABreak wrote: 02 Feb 2025, 12:58 Well you're half right Jay!
Marc, as always, you are a legend, thank you sir... O7
Jay-Bruce
x 280
Oh, one more thing, can I get the part numbers for item 4, the attachment for the pickup linkage to go on?
x 6956
Sure:
Left Balljoint Support, part: 352511, £11.35
Right Balljoint Support, part: 352512, £11.35
