6speedmanual
Re: Citroen and Peugeot Parts Requests
Hi
Sorry if this answered elsewhere but I just seek clarification....
If I donate, can I then access the PSA parts info directly or do I have to post psrts enquiries on here for an assigned member to look them up?
Cheers
Pete
Cheers
Pete
- x 6957
You need to post here for your parts requests, we do not provide direct access.
DanCD
- (Donor 2021)
Hi Marc,
Could you please give me the part number(s) for the coolant expansion tank and cap please?
Let me know if you need my car details again
Cheers,
Dan
Cheers,
Dan
Dan
- x 6957
Here you go Dan, note the tank (if buying new from Citroen) already includes the cap, but I've shown both part numbers in case you are searching second hand.
Degassing Tank: 1323FA £57.29
Cap: 1306J5 £6.38
Direct from Citroen, VAT Inc. as of today.
Cap: 1306J5 £6.38
DanCD
- (Donor 2021)
Brilliant, nice and quick as usual
Cheers Marc, have a good evening!
Dan
Dan
Dan
- x 6957
No worries, you too.
cs101
- x 6
Please can you give the part number of the missing inner liner (Front Driver side) for my van as in picture.
My VIN is VF3**************[VIN obfuscated, can be read by forum staff].
Reason: Corrected Image Tags
- x 6957
Sure, here you go, item (10), part: 9808363380, price £131.81 inc. VAT from Peugeot.
If it's another part of the trim you need, then let me have the item number from the diagram.
- x 3306
I would pay a visit to your local scrapyard. I had to get an arch liner, and Citroen wanted £85 for a new one. My local scrappy had one (intact with all of the fixing points) for £15.
cs101
- x 6
Thanks Marc. Will also look at the scrapyard, Hell Razor5543, thanks.
cs101
- x 6
Peugeot dealer does not have in stock. Only small piece is missing as in above picture. Any ideas for modification or other model which can fit in the place, please?
- x 6957
I'm not sure which 'small' piece you are referring to - the liner is quite a large piece.
You'll find that most spares, apart from service items are order-in only now in common with lots of suppliers. It depends on whether they have to order them in from France or they have some stock in the supply chain storage. I was recently waiting for a rear wheel arch trim and the first 3 were damaged on arrival - all from France. Finally got the fourth one undamaged, but all came in from France - about 5-7 days for each order.
cs101
- x 6
Marc, if you look at the picture the section where u can see the intercooler, went missing after my van intercooler was damaged. All the other part of the arch liner is intact. From this hollow section all the dirt goes into the engine from the front wheel.
cs101
- x 6
- x 6957
Hard to see if that hole is from the arch trim or one of the other bits (3) or (9). Probably have to compare with the other side to confirm which it is, but anyway if you need the part number if any of the other items, let me know.
