Xac's adventures with Cassy (and friends + wife)
x 8368
Better than Bletchley!
So do they shake it all about if she passes?
Xaccers
x 188
Unread post by Xaccers »
At the mot centre now. Very clean toilets, even the coffee isn't that bad. Free wifi too!
Cassy's just had the shake down on the ramps, now they're checking the back wheel
DIY sphere tool
Xaccers
x 188
DIY sphere tool
Xaccers
x 188
Well she failed :(
O/S brake light not working, probably just the bulb gone.
Flexible brake lines need replacing.
Rust on the N/S back door wheel arch join, where it opened up from the prang last year and has been sat over all the snow and gritting, the edge of the upper section broke when it was hit with a hammer during the test, so I need a plate welded in.
DIY sphere tool
Xaccers
x 188
Popped up to GSF in Northampton yesterday and picked up two flexible brake hoses.
Swung by mum and dad's to pinch a bulb out of one of the LX's rear clusters, but it turned out to be dud so I'll have to buy one tomorrow.
I've found a mobile welder, and emailed them a copy of the photo so hopefully on Tuesday they'll give me a quote.
I'll also send it off to a few other places and see what they can do.
So hopefully I'll be able to get it re-MoT'd next weekend.
DIY sphere tool
x 1485
I remember seeing something about repairing that area on a French(?) forum - was quite a big hole by the time it had been cleaned up, and the metal is pretty thick there. I would offer to strip out the back seat / carpet / seat belt etc so you're only paying for the welding - I'd also be tempted to take an angle grinder wire brush to it to clean it up so you can see the extent - it will be surprisingly big before you get to solid metal! The actual welding shouldn't be that bad, but that depends on what you find under it that also needs repairing....
Xaccers
x 188
Finding somewhere that's interested is proving to be a problem.
The vehicle repairers say they're just interested in replacing panels and pulling dents out.
Danielle brought home a copy of the local paper and there's two adverts in there which mention welding repairs along with websites/email so I've sent them the pic and asked for quotes.
DIY sphere tool
x 8368
Xac wrote:Finding somewhere that's interested is proving to be a problem.
Good gracious :shock: Now I am surprised.
If that's the case, I just may go and buy a MIG and practice the art (but not on Cassy just yet!)...
I've been out turning up ram bushes on the lathe this evening. I've made one for Juliet...
Xaccers
x 188
Thanks jim you're a star!
DIY sphere tool
red_dwarfers
x 58
Unread post by red_dwarfers »
I'm sure there are going to be skilled welders about that don't necessarily want to advertise their presence but I guess the only way you'd get to know is word of mouth. My Dad is one such person, make anything out of anything he can. Toned down on it all now though and a bit far away :lol:
Once you've got the technique, welding isn't too bad. Its getting the correct technique for each situation, that's the problem, all comes down to practice.
Kev
'19 C4 Cactus 130 Flair
pug_owner2002
x 3
Unread post by pug_owner2002 »
Go on Jim, get a mig and give it a go.
I'm sure that you'd master the art of welding. After all you can sort an autobox out.
I've done a fair bit of welding on previous cars in the past, but wouldn't dare venture into a gearbox. :lol:
R Reg Phase 2 306 DTurbo (Blaze Yellow) (Sold)
X Reg Phase 3 306 1.4 LX (Sold)
03 Renault Scenic Dynamique +
03 Seat Leon 1.9 TDi
52 Nissan Almera 1.8 sport+
x 1485
No MIG Jim? What are you playing at over there :lol: Invaluable for all sorts of things, surprising how often a blob of weld is required to make things easier. I've got a Clarke 150TE MIG - not all that cheap at around £250, but it makes decent welds, even in my hopelessly cack-handed hands :wink: For the cost you are likely to have to pay someone to fix Xac's car the MIG will nearly pay for itself - and for a hobby machine it will go on for ever. MIG is pretty easy, but as always care is required to ensure you are getting decent penetration so you end up with a sound job. For that job on Xac's it might be worth a trip to the scrapyard and cutting out the relevant section of a scrapper to weld into place - it will save a lot of fabrication work!
With a MIG you could then weld yourself a decent set of ramps - see Shane's website on Aussiefrogs for some inspiration!
x 8368
You're right Richard, no MIG :(
What I do have, and have had for years is a very high quality arc (stick) welder that will, with care, weld quite thin stuff but its still risky using it on car bodywork. It's an old Oxford. Oil filled with a tap changer and 50V and 80V outputs. It goes from a few amps right up to hundreds...
I agree a welder is an invaluable tool to have around the workshop and the old arc welder gets plenty of use. I'd not be without it :D
But, it really is time I got myself a MIG or, if the purse strings allow, I may just bypass the MIG stage and get a TIG outfit. I can see many uses for a TIG outfit...
What I'd really like is an Oxy-Acetelyne outfit but I cannot justify it :(
red_dwarfers
x 58
Get yourself a carbon arc weld attachment for you arc welder, not quite as accurate as Oxy Acetylene but it has saved the day for us on many occasions when a propane torch just isn't enough.
Saying that though, where you would get one these days im unsure of. Trouble enough getting the carbon rods for them. Machine Mart saved the day in the end though and at a good price!
Kev
Xaccers
x 188
One company has come back, they can't quote on the photo alone, but are estimating £80-100 + VAT
DIY sphere tool
