I am an Activaist-v6 and a 2.1Estateerr
x 1995
Re: I am an Activaist-v6 and a 2.1Estateerr
Unread post by Stickyfinger »
OK, lets start on the lower arms for Daffodil.....start by pulling back the carpet to access the lower arm inner bush clamp bolts...
OH WAIT a MOMENT !
Soggy .....VERY soggy...bu@@er !....so, seat out, carpet folded out of the way and soggy underlay remover. ((Put in the washing machine on fast spin/radiator to dry).
Onto the moulded foam sound barrier foam on the foot-plate/bulkhead.....OH WAIT....SOGGY !!!!
So remove that...OH WAIT.....it has all the peddles etc bolted down ON TOP of it.....bugger that for a game of Mandelson's....out with the Stanley knife tomorrow as rain stopped play.
Oh yes, the cover is a mastic tape, brittle, so it fell apart and I will need to treat and paint the areas moisture has attacked scratches etc so the floor does not rust out later :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :)
x 8407
Good job you've found that damp before it goes on to cause bigger problems Alasdair.
Time to have all the carpets out, dry them and whilst they are all out it'll be easier to determine where the water is getting in.
The Series 2 AX carpets are different to those in a Series 1 like mine. The underlay is separate and the carpets are not really carpets in the accepted sense - just thin mats! It's why the Series 2 is a bit more refined and quieter than the Series 1...
x 1995
With the lower arms now done (thanks to slightly less inclement weather) and the Xantia all running great with its new set of selector rods, clutch clip and mount....it is onto getting the little AX ready for its MOT. (looks like petrol is going to be cheaper than diesel for a bit thanks to world events)
Anyway, it;s logical then to fully machine polish the AX (Daffodil) back to her original White rather than a slightly yellow shade of off-white (does Farrow and Ball have a name for this shade of white ?) before assessing/adjusting the rest of its bits before the MoT
Look at the rear wing to see the old discoloured polish over the paint....Polymer "polish" does this over time, white shows it biggly.....I blame Obama and Biden for this !
A clean car passes an MoT, a known Man-Fact
Reason: Amended text to comply with new legislation and forum rules.
x 2354
Unread post by MattBLancs »
Stickyfinger wrote: 11 Mar 2026, 16:45 does Farrow and Ball have a name for this shade of white ?)
Well, clearly "old English white" is a thing https://paintman.co.uk/shop/rover-group ... YyCiAztUJ3
but not applicable for this situation - so obvious suggestion
Spoiler: show
old French white!!
:rofl2:
x 1995
Last edited by mickthemaverick on Wed Mar 11, 2026 6:07 pm, edited 1 time in total.
Ohh for goodness sake... I covered all the mad Bu 66 ers fairly :) :)
Anyway, with a naming dispute over the Peoples Front of Judea or the Judean People Front or not, if a world leader eats to many satsumas for his own good or if a headdress makes you a little bit "off the rails" in a hot climate yet to be decided as the gulf is not wide enough between the choices...........................I decided I had better move on and will not drone on about it anymore.......so I finished the full machine polish to remove the old "wax" and apply a fresh polymer glaze then topped that with a full "wax", that should last the summer :)
So all done
x 1995
8ugger, the sinker Xantia's passenger footwell (only) is full of water today....
x 8407
Stickyfinger wrote: 13 Sep 2026, 13:05 8ugger, the sinker Xantia's passenger footwell (only) is full of water today....
Not a problem Alasdair...
It's now identifying as a:
Embrace its brave decision to choose its own way forward in the twilight years of its life :)
x 1995
The best choice for any Pluriel...........not that it would burn as they are normally full of water and I would not want to harm the resident goldfish :)
James did offer to shoot a couple of holes in the footwell of the Xantia, an option :)
x 8407
Stickyfinger wrote: 14 Sep 2026, 08:42 James did offer to shoot a couple of holes in the footwell of the Xantia, an option :)
:lol: :lol:
