Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
GiveMeABreak wrote: 08 Sep 2024, 14:15 No, that's not right. 13510 is the unique build date for your vehicle - I can't advise of the exact change over of facelifted models but I believe the MK 1 3008 had a facelift in 2014 sometime. The MK II was released at some point in 2016 and the MK III sometime in 2024.
0952 isn't a valid fault code, but if you do find it, post it up on the technical Forum please, not in the parts section. When I see that, I'll see if I have a diagram or not and post it there.
It’s on the audio CAN so not sure if there should be a prefix to the 0952.
This is a facelift model as far as I am aware not the very early model which did surprise me seeing as it was built in 2013. It has the little dinks up on the headlights at the side.
mliapis2003
Unread post by mliapis2003 »
Hi, I recently had my engine replaced, but I am not sure if it was really replaced!. The mechanic said so, but I don't feel any difference. Since I don't have access to the original engine S/N can you provide me the info? My VIN number is: VF7**************[VIN obfuscated, can be read by forum staff]. Thanks. (Sorry for my poor English, I live in Greece).
x 6945
Sure, give me a second and I'll get your build sheet for you.
Vehicle Characteristics
Vehicle familyXSARA PICASSO
AS/RP N°11060 FV 2 1029
Warranty Start Date29/11/2007
Engine Serial Number10 FX6P 3185873
OPBP00A
BERe2*98/14*0153*15
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYXSARA PICASSO
SILHOUETTEFAMILY SALOON
TRIM LEVELLOW / HIGH
ENGINETU5JP4 INJECTION
TRANSMISSIONBVM5
PAINT TYPEMETALLIC PAINTWORK
BODY COLOUREZR - PAINT ALUMINIUM GREY
INTERIOR TRIM TYPEREPS + SPOTTED "SV"
UPHOLSTERY COLOUR"FZ"
GEARBOX (CHARACTERISTICS)BE4-5V MANUAL GEARBOX
DEFINITION TO FOLLOWRANGE ACTIVITY
ENGINE (TYPE)TU
BADGEWITHOUT BADGE
STEERINGPOWER STEERING
Fuel Supply-Engine
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
CYLINDER BLOCK (MATERIAL)CRANKCASE CAST IRON
FUELUNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)EURO 4 ENGINE EMISSION CONTROL
ENGINE (TYPE)TU
OIL COOLERWITHOUT OIL-WATER DISTR CHAMB
COOLING MOTORRADIATOR 27MBA - 21 DM2 - PAS 1.1
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
POWER VARIATION (ENGINE)STANDARD POWER
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
DEVICE (ANTIPOLLUTION)WITHOUT ANTI-POLLUTION DEVICE
VEHICLE TECHNICAL DEPOLLUTIONL5 VEHICLE TECHNICAL DEPOLLUTION
PARTICLE FILTERWITHOUT PARTICLE FILTER
FAN140W AERO 2 SPEED FAN
INJECTION ASSOCIATED VARIANTMOUNTING MAGNETI MARELLI
THROTTLE HOUSING (ENGINE INLET AIR CIRCUIT)MOTORISED THROTTLE BODY (ENG AIR INTAKE)
Gearbox Transmission
TRANSMISSIONBVM5
FINAL DRIVE RATIOREAR AXLE HYPOID GEARSET 17 X 71
WHEEL STYLE15 INCH STEEL WHEEL
CLUTCHHYDRAULIC CLUTCH
SEAL, WHEEL ENDWHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL ENDAXLE-SIDE JOINT JB2A
DIFFERENTIAL (GEARBOX)DIFFERENTIAL 77
TYRE (SIZE, TYPE)185/65 R15 88H NON REINFORCED TYRE
WHEEL (TYPE)STEEL WHEELS
GEARBOX TYPEGEARBOX BE4R
Suspension-Steering-Brakes
ABSWITH ABS BRAKES
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR DIAM 21
FRONT ANTI-ROLL BARFRONT ANTI-ROLL BAR DIAM 21
BRAKE TYPEVENTILATED FRONT DISCS/REAR DRUMS
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMWITHOUT ELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANTBOSCH ABS 8 0
Body Fittings
TOWBARWITHOUT TOWBAR
WHEEL EMBELLISHER (STYLE)15 INCH 16-SPOKE BAYONNE STYLE
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR MANUAL-FOLD BACK
WINDSCREEN WIPERFRONT WIPER BLADE W/O RAIN SENSOR
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
LUGGAGE RACKWITHOUT ROOF BARS
FRONT FOGLAMPNO FRONT FOG LIGHTS
EXTERIOR ACCESSORIESNEUTRAL EXT HANDLES+SIDE MOULDINGS+EXT MIRRORS
SUN ROOFFIXED ROOF
BUMPER TRIMDYED BUMPER STRIP
GLASS (APPEARANCE)TINTED
Interior Fittings
REAR SEAT3 SEPARATED REAR SEATS (1 SLIDING)
REAR SEATBELTREAR 3-POINT 3 INERTIA REEL SEAT BELT
FRONT SEATBELTPYROTECHNIC SEAT BELT WITHOUT ALARM
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
SPEED GRADUATIONSSPEED GRADUATION IN KM/H
CONSOLEWITHOUT CONSOLE
DRIVING POSITIONLEFT-HAND DRIVE
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
DASHBOARD EQUIPMENTCAPPING V098 + SOLID COLOUR FRONT PANEL
LOUDSPEAKERMOUNTING 4 LOUDSPEAKERS + 2 TWEETERS
RADIO CONTROLSREMOTE RADIO CONTROL
SCREENING (BLIND, SIDE SUNBLIND, SUNROOF)WITHOUT REAR BLIND
DRIVER SEAT ADJUSTMENTDRIVER’S LUMBAR SUPPORT
FRONT SEAT ARMRESTFITTED WITH ARMREST
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
REAR WINDOW LIFTMAN CTRL REAR WINDOW LIFTER
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGDOUBLE FRONT LATERAL AIRBAG
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
ADDITIONAL AIR CONDITIONINGWITHOUT ADDITIONAL AIR CONDITIONING
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED DOOR MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
RADIO RECEIVER"RD3" RDS COMPACT DISC AUDIO SYSTEM
REFRIGERATIONSINGLE AIR CONDITIONING
CRUISE CONTROLWITHOUT SPEED CONTROL
LOAD SPACE STORAGEWITHOUT LOADING RUNNER
OBSTACLE DETECTION SYSTEMWITHOUT OBSTACLE DETECTOR
TRIM ADAPTATIONWITHOUT MOULDING ADAPTATION
STEERING WHEELLEATHER STEERINGWHEEL
Electrical
ALTERNATORALTERNATEUR CLASSE 8+
BATTERYBATTERY L2 400
STARTER MOTORSTARTER MOTOR CL 3
SPECIAL LIGHTINGWITHOUT PARTICULAR LIGHT
MULTIPLEXINGMULTIPLEXING ASSEMBLY CAN VAN
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
REFRIGERANTREFRIGERANT LIQUID R134
SLAVE CONTROL UNITBSI COMM 2000
LedZep
x 30
Unread post by LedZep »
Hi Marc.I'm looking for this part of the photo.I guess it is some kind of oil level-temperature sensor. It is placed and fit above oil sub and close to oil regulator solenoid , oil pressure switch and filter.No s/n on it.VIN VF3**************[VIN obfuscated, can be read by forum staff] . Thanks in advance.
x 6945
Hi, no problem, this is your oil gauge:
(20) Oil Gauge, part: 9804663580, £25.01 VAT Inc.
Mathemagic-1970
Unread post by Mathemagic-1970 »
I'm looking to replace the rear under tray on my Grand C4 Picasso 65 plate 1.6 HDi 120
My car has the optional space saver spare wheel.
I'm looking for the plastic cover that goes under the wheel from the rear bumper forward - apologies, I'm not sure of he correct name. In the past my vague memory seems to think I used to unhook the sheet just behind the bumper and lower it down to be able to access the spare wheel and case holding the jack.
Any help on what it is called and a part number very much appreciated.
Thank you in advance for any help.
Tony
x 6945
Hi
Let me know which item from the following you need a part number and price for, but see my note below first...
Note: You don't have 3, 5, 6 or 7 for this vehicle, in case you thought they were 'missing'. They were never fitted for this specific vehicle.
Mathemagic-1970
Thank you for the reply Marc,
I'm now doubting myself. I was convinced that there was an undercover similar to part 70 but for the part of the car from the rear wheels back, but am now not so sure.
I'll have another look when the car is (hopefully) fixed at the end of the week.
Tony
x 6945
Part (70) is just a fixing that secures (1) to (4), Tony, but you should have Items (1), (2) & (4)
Mathemagic-1970
Ah, sorry, me reading the diagram incorrectly.
I've previously had to replace the big part - number 1 and thought there was something similar at the rear of the car.
x 6945
No, never fitted when it was built at the factory - may be because of the exhaust / engine / emissions system or other equipment fitted on this vehicle.
Mathemagic-1970
Thank you for your help Marc.
Best wishes
JustADriver
Unread post by JustADriver »
Hi Marc,
first of all - thank you for your effort. If the technical terms dont make sense please let me know, a translater has been used for it. Now to my issues :D, a checkup has revealed the following:
  • Headlight, left fog light not working
  • Suspension, shock absorber of the 2nd (rear) axle on the right is leaking
  • Axle / Suspension, front axle wishbone on the left lower side worn out
  • Axle / Suspension, front axle wishbone on the right lower side worn out
  • Engine / Drive, dust boot (driveshaft) front right torn
  • Engine / Drive, dust boot (driveshaft) front left torn
Except maybe the foglight (if its the bulb, or fast to just replace the whole part), I would like to replace all the mentioned parts. I´ve been told, that the wishbone should be just replaced, not fixed, because it will be cheaper than fixing the current ones. I would like to do that.
Its a C5 Exclusive HDi 200 from 2011, VIN: VF7**************[VIN obfuscated, can be read by forum staff]
DAM: 12541
One more thing, if its not too much trouble to ask. Are there aftermarket brands you can recommend? Or in general parts you can recommend in this case?
Appreciate your help!! If there is anything else, please let me know. Thanks!
x 6945
No problem, leave it with me for a few minutes
The fog lamp bulb is shown so assume you need a bulb if it's not working?
Fog
(10) Font Fob Light Bulb, H8 12V 35W, Part 6216E8, £46.73
Cheaper bulb, part: 1637237980, £18.85
However, if water has gotten into the light unit and it's misting up and you require the compete unit (which includes the bulbs for the indicator and the fog lamp), then:
(1) Complete Fog Lamp, (Left), part: 6208J4, £197.56
Suspension
(1) Rear Suspension Strut, part: 527299, £236.58
Front Axle
(6) OEM Citroen Original Wishbone (Left), part: 9663980880, £614.28
Citroen Cheaper Alternative, part: 1682733380, £380.03
OEM Citroen Original Wishbone (Right), part: 9663980980, £579.56
Citroen Cheaper Part: 1682733080, £339.68
Note: Be aware that if you get a clunking when driving off or braking, this can be the bush that I have highlighted in red that is in the Hub Bearing Assembly, which is not sold separately. You can buy these and replace them independently from elsewhere.
Driveshaft Boots
(3) Driveshaft Gaiter Kit, (Wheel Side), part: 3293C8, £79.61
Driveshaft Gaiter Kit (Axle Side), part: 3287C9, £50.33
These are for official Citroen parts, but now that you have the correct part numbers, you can search on these to find alternative suppliers.
JustADriver
Good evening and thanks a lot for the effort Marc!
I do have an additional question regarding the two wishbones. During some research I came accross the part description 3520.W2 & 3521.S5 being mentioned as made of aluminum and then also 3520.X6 & 3521.T7 for being made of steel. Can I use both for my mentioned car? Is there a preferred one?
Rob
