Xantia V6 broken exhaust (update: and rough low rpm running)
x 8302
Re: Xantia V6 broken exhaust (update: and rough low rpm runn
Mandrake wrote: Can you describe where this return banjo is and what it looks like so I can check it for leaks ? :? I hope its not low on oil, I really should have checked it weeks ago but I wasn't sure whether I was chasing an engine problem or gearbox or both at the time...
One picture is worth a thousand words Simon,
Here's a typical leaky one:
The leaks are caused by corrosion to the aluminium washers each side of the banjo bolt. A bad leak here can drain the 'box in 150 miles as the pipe is the main oil feed from the cooler...
If you find you do have a leak there, let me know as I have quite a stock of washers...
Mandrake
x 694
Unread post by Mandrake »
Thanks Jim,
That's very helpful. I won't be able to check it today as its been p***ing down, but will check it as soon as I can. Will also check the oil level as soon as I can in case it is low, and keep the driving to a minimum until I have.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 8302
Simon, a source of LT71141: Opie Oils
Mandrake
x 694
CitroJim wrote:Simon, a source of LT71141: Opie Oils
Jim you're a star :-D Do you think I need 6 litres or will 5 be enough for one change with a bit left over ? (I'm watching the ££ until I'm paid :lol: )
Simon
1978 CX 2400
x 8302
5 should be enough Simon but I'd tend to play safe and get 6... But then even if five only brings it to the minimum then you'll be OK... It's better to err on the minimum side rather than the maximum I find.
You may also find, if you ring him up, you might get some discount. I have a feeling in the back of my mind that he was offering clubs and forums a bit of a discount at one time. Always worth a go :wink:
EDIT: Do compare him with the price of the stuff from your local dealer, Citroen or Pug.
x 5652
CitroJim wrote:5 should be enough Simon but I'd tend to play safe and get 6... But then even if five only brings it to the minimum then you'll be OK... It's better to err on the minimum side rather than the maximum I find.
Wasn't/isn't it oilman of this parish?
x 8302
myglaren wrote: Wasn't/isn't it oilman of this parish?
I believe it may well be Steve, now you come to speak of it...
Mandrake
x 694
Too late, I've already ordered 6 litres from Opie :) My days off this week are Thursday/Friday so I'm hoping it will arrive by then. (I chose priority delivery as its only £3 more)
Now to find a funnel, strainer, pipe, and something to catch the old oil...
Simon
1978 CX 2400
x 1480
I certainly didn't notice it being wet with oil underneath yesterday Simon - that banjo should be easy to check though just by looking under the wheel arch.
Plenty of oil catching facilities here if you need to make use... :lol:
Mandrake
x 694
Thanks Richard,
I should be ok doing the oil change, also now that I think the groan is indeed the gearbox I'm quite concerned about unnecessary long distance driving until I've done at least one change. It was doing quite a bit of groaning and complaining on the way home on Saturday, it seems to get worse on long trips (oil thinning with temperature perhaps ?) and every groan could potentially be damaging the clutches/brakes, so I don't want to push my luck. :?
All going well I'll get it done on Thursday.
You're right, I don't think there are any significant oil leaks, engine, gearbox or hydraulic for that matter. The engine oil and hydraulic oil has never needed topping up and there are never any oil spots in my park... thats not to say that there couldn't be a very slow drip from the gearbox that occurs only at high temperature while driving of course...
When I do the change I'll check the level first and also check the banjo for signs of leaking, if I see any sign of a leak I'll get replacement washers and replace them when I do a second change in a few weeks. (I assume that it's best to change the washers while the oil is drained to avoid losing half the oil on the ground :lol: )
Simon
1978 CX 2400
x 8302
Mandrake wrote:I assume that it's best to change the washers while the oil is drained to avoid losing half the oil on the ground :lol:
Nope. Unless you do it with the engine running Simon, you'll loose hardly a drop :wink:
Mandrake
x 694
Ok, I must remember to do the washers with the engine turned off then :lol: :mrgreen:
Simon
1978 CX 2400
lexi
x 134
Unread post by lexi »
What does Lexia say about AT oil tenps?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Mandrake
x 694
The Lexia can show gearbox oil temperature, the maximum I've seen is 100 degrees during spirited country road driving, which seems to be in line with expected temperatures according to the 4HP20 training manual...
Simon
1978 CX 2400
Mandrake
x 694
Well it looks like 6 litres of yellow cats pee, err I mean LT71141 has arrived. :lol: Actually it doesn't smell of much at all which just goes to show how poor my sense of smell is... :roll: Ordered late on Sunday night from Opie Oils, sitting on my door step tonight, can't complain about that!
All going well I'll get it changed on Thursday and cross my fingers like crazy that it either fixes the groaning or makes a major improvement... [-o<
Simon
1978 CX 2400
