Time to cut some Oak blocks (glad I kept the old gate posts
I am an Activaist-v6 and a 2.1Estateerr
- x 2006
Re: I am an Activa owner...a V6 and I am an addict
Will do.....thanks
- x 2006
More proof work with the headlamp mountings/dress plate
- x 8437
Coming along nicely Alasdair
- x 2006
More work
mounts positioned (temp with hot glue), lamps orientated and DRL holes drilled.
I ([may] move the DRL's to the off side and use a high power micro spot lamp on the left, I need to check sizes.
- x 2006
a little photoshop jiggery and I have this
daviemck2006
- x 485
I like that. Big improvement but quite subtle!
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 8437
Seconded!daviemck2006 wrote:I like that. Big improvement but quite subtle!
- x 2006
I had better crack on with it then
- x 8437
You had! You may even need to start up a production lineStickyfinger wrote:I had better crack on with it then
- x 2006
If I can get it worked out the way I would like Jim, I will ask if anybody wants a set of the backing plates and mounts cut at the same time I have mine done.
- x 8437
That sounds like a good plan!Stickyfinger wrote:If I can get it worked out the way I would like Jim, I will ask if anybody wants a set of the backing plates and mounts cut at the same time I have mine done.
furriegurrie
- x 40
Can't you put them closer together and more to the outside ofthe car? This will look better I think. Might even create enough space foe a third light...
- x 2006
It is not possible to do that due to the shape of the main lamp "box", the shape at the back (on the angled center-side) prevents a lamp unit being fitted in this area.furriegurrie wrote:Can't you put them closer together and more to the outside ofthe car? This will look better I think. Might even create enough space foe a third light...
As it is the "box" needs a couple of cut outs to allow the clearance/fitting of the top mounting points.
I am looking at Micro FOG lamps for this area and converting the bumper mounted fogs to long range driving lamps but when I was trying the layout (with drawings) it looked a little "Fussy" with three lamps.
I am also looking at constructing....."Double Chevron DrL's"......but that will be for later as I need to "cast" the chevrons in an opaque plastic so they glow bright (like BMW angle-eyes)
- x 2006
Not much going on down here, I did start up/run up the donor V6Activa, it started on the button !
- x 8437
ExcellentStickyfinger wrote:Not much going on down here, I did start up/run up the donor V6Activa, it started on the button !
