x 6950
The procedure for your C8 is the same as the one listed here. Follow the relevant info under the degassing section for Non-Euro 6 engines.
Tom309
x 14
Unread post by Tom309 »
Hi Marc,
There seems to be some confusion over which clutch kit is needed for my brother’s 307. Please would you let me know the correct one. VIN VF3**************[VIN obfuscated, can be read by forum staff]. Thanks, Tom
jamescarruthers
x 47
Unread post by jamescarruthers »
Hello parts searchers! Is 1717EC still available and are there any alternatives available?
The two front flex is have gone on my C6 petrol.
Likely going for repair but always worth a second check on here for new availability.
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
x 6950
Tom309 wrote: 03 Nov 2023, 16:04 Hi Marc,
(8) Clutch Kit
Pro Clutch Kit, part: 1611269280, £462.26
Cheaper Clutch Kit, part: 1636264380, £180.30
Exchange Clutch Kit, part: 2051W4, £251.17
Difference is the cheaper clutch kit is a non-OEM version, whereas the Exchange one is a refurbed original.
All VAT inc. From Peugeot.
x 6950
jamescarruthers wrote: 03 Nov 2023, 20:59 Hello parts searchers! Is 1717EC still available and are there any alternatives available?
Sorry James, not from Citroen.
(3) Exhaust Intermediate Pipe, part: 1717EC (No Longer Available)
The part does have some info, not sure if it's of any help though: TR PSA 4211 PSA 4212
These have one in stock:
https://bartebben.com/catalog/product/v ... 717EC-NFP/
jamescarruthers
x 47
Yikes, 400 EUR for a used exhaust part! Hopefully repair comes in cheaper. Chevronics are hopefully sending it off to PD Gough.
Thanks very much for checking and I will try those other numbers too.
1987 Volvo 480 ES
Tom309
x 14
Hi Marc, sorry, please can I have the part number for the clutch flywheel as well, thanks again
x 6950
Details below Tom, but be aware this vehicle does not have Dual Mass Flywheel....
(10) New Flywheel (DIAM 230 - 133 DTS), part: 0532N0, £632.50
NorfolkVroom
x 5
Unread post by NorfolkVroom »
Could I have the part number for the under engine splash guard (the long one that reaches past the front wheels), on a MK1 Peugeot 3008 (1.6 HDi 2014) please?
Cheers
x 6950
@NorfolkVroom: VIN Please
the_oaf
Unread post by the_oaf »
Hi all,
My wife has a 2015 Citroen C4 Exclusive 1600cc Hatchback, in which the electric window mechanism within the drivers side door needs replacing, along with a number of clips than hold the door panel in place, that the mechanics broke looking into the issue.
I have pictures if needed, but can't see a way to post them... so if anyone can advise me on that, it would be great.
VIN no. VF7**************[VIN obfuscated, can be read by forum staff]
Thanks,
Matt.
x 6950
Hi Matt
Electric Window Motor
(3) Electric Control Window Lifter (Right), part: 9802531780, £454.91
Door Clips (Let me know if not this one):
(75) Clip, part: 9345ZN, £0.61
All VAT inclusive direct from Citroen.
NorfolkVroom
x 5
Marc; VIN: VF3**************[VIN obfuscated, can be read by forum staff]
x 6950
NorfolkVroom wrote: 06 Nov 2023, 08:40 Could I have the part number for the under engine splash guard (the long one that reaches past the front wheels), on a MK1 Peugeot 3008 (1.6 HDi 2014) please?
Cheers
Let me have the item numbers for the parts you need numbers for :wink:
NorfolkVroom
x 5
1, 70, 71, 72, 74
Though 1 isn't an exact match, on that diagram it's a much stumpier version that the one I have.
