P0339 fault code
PaulC5
x 709
Re: P0339 fault code
Unread post by PaulC5 »
Did you have this problem before the timing belt was replaced ? Have you checked the sensor wiring all the way back to the ecu in case it got damaged during the belt replacement ?
This site has a few things to check but most have already been done https://a-premium.com/blogs/p0339-crank ... tW0FGoijlO
