C3 Phase I random starting issues
ozvtr
x 256
Re: C3 Phase I random starting issues
Unread post by ozvtr »
frenchc3 wrote: 14 Jun 2026, 08:05 The only key I have is a simple key which is a copy of the original Citroen key (the two originals were lost or stolen). In the last few months I've been getting the message "anti theft fault" but not always, and the car will not ignite. It seems I cannot turn off the car and restart it immediately, but I have to remove the key and wait, as mentioned in the other thread as well.
Unless the stop/start fails EVERY TIME you get the anti theft fault, I would say you have two faults. One in the key and one in the stop/start.
As I said, if the engine ECU does not get the correct code from the key, the engine will never start!! Or in this case "turn over". So I would suspect the RFID chip in the key. Being a "copy" it could be a bit dodgy.
Something to try: next time the engine fails to "turn over" AND you get the anti theft message, see if the interior light turns on when you remove the key. Trust me on this one. :wink:
frenchc3
Unread post by frenchc3 »
ozvtr wrote: 16 Jun 2026, 02:04
The star/stop fails message comes on every time, it's the anti theft that only comes on occasionally. I just tried what you suggested, the internal light doesn't turn on when I get the anti theft message and I remove the key. It seems also that once I get the anti theft message I have to wait a bit to try again.
Another strange thing I noticed, I was able to start the car once without keeping the brake pedal pressed, that's very strange as usually you get a message if you don't have the car in N and the brake pressed and the car won't even attempt to start. I also noticed that if I can start the car if I do it quickly before the anti-theft message comes on. I wonder if the "energy saving mode" also has anything to do with it. It seems it comes on too quickly.
Is the starter/alternator the culprit? I looked it up and it's very expensive, I don't really have the money for it. Should I start by changing the battery? What can I do? :?
PaulC5
x 705
Unread post by PaulC5 »
When it does not start if you leave the key in the ignition switch and open the driver's door do you get a warning message ? Most cars do this provided the key is being recognised by the immobiliser.
ozvtr
x 256
frenchc3 wrote: 16 Jun 2026, 17:29 I just tried what you suggested, the internal light doesn't turn on when I get the anti theft message and I remove the key. It seems also that once I get the anti theft message I have to wait a bit to try again.
OK. When you turn the ignition off, the car activates the transponder reader around the ignition barrel. While it gets a "ping" from the transponder in the key, the car knows that the key is still in the lock. When the key is removed, the "pings" stop, and the car knows the key has been removed, and so it turns the interior light on. BUT if it "thinks" that there never was a key in the lock in the first place, it wont turn the interior light on. So the car was NOT getting "pings" from your key, at any point in time! So I postulate that the transponder in the key is dodgy. That's causing your "anti theft" fault and the engine not starting, UNDER THOSE CIRCUMSTANCES!
frenchc3 wrote: 16 Jun 2026, 17:29 Another strange thing I noticed, I was able to start the car once without keeping the brake pedal pressed, that's very strange as usually you get a message if you don't have the car in N and the brake pressed and the car won't even attempt to start.
The brake switch has two sets of contacts. One set actually turns the brake lights on and off. The Other "auxiliary" contacts are used to both check the position of the brake light contacts AND signal to other systems that you have put the brakes on. The engine, the auto gearbox and other systems (stop/start in this case) use the data of whether you are using the brakes or not. These contacts are known to cause trouble. Sticking on or sticking off! A classic fault is not being able to get the automatic shifter to come out of PARK because it wont unlock when you put your foot on the brake pedal. So I'm not surprised.
frenchc3 wrote: 16 Jun 2026, 17:29 I also noticed that if I can start the car if I do it quickly before the anti-theft message comes on. I wonder if the "energy saving mode" also has anything to do with it. It seems it comes on too quickly.
I think this is to do with the bad transponder chip in the key more than anything.
frenchc3 wrote: 16 Jun 2026, 17:29 Is the starter/alternator the culprit? I looked it up and it's very expensive, I don't really have the money for it. Should I start by changing the battery? What can I do? :?
I'm sorry but I don't know. There isn't enough information.
I would recommend finding someone with a LEXIA or a scan tool that can read the fault codes stored in the stop/start ECU. That should give you a clue as to where the fault lies. Those little OBDII scanners wont do it!
The fault is most likely in the stop/start alternator, the stop/start ECU or the wiring and electrical connections. Replacing things willy-nilly could prove fruitless and expensive.
ozvtr
x 256
frenchc3 wrote: 16 Jun 2026, 17:29 Should I start by changing the battery?
No. I was a bit premature in my first post. That auxiliary battery has nothing to do with your current problem.
If you started loosing the time or the dash flickers when the stop/start restarts the engine, then maybe think about it. But considering that you are turning off the stop/start...I wouldn't worry about it all.
frenchc3
ozvtr wrote: 17 Jun 2026, 02:54 I'm sorry but I don't know. There isn't enough information.
Thanks a lot, this is very useful information, and I think we can conclude there are two separate issues here that both relate to starting the car. I will try to get a new key as well and get a complete scan of the codes.
frenchc3
ozvtr wrote: 17 Jun 2026, 03:14
I agree on the aux battery, I was thinking more about replacing the main battery. I am pretty sure it's not the problem, but I guess I will have to replace it sooner or later.
ozvtr
x 256
frenchc3 wrote: 17 Jun 2026, 07:39 I was thinking more about replacing the main battery. I am pretty sure it's not the problem, but I guess I will have to replace it sooner or later.
Oh, OK. What I said earlier about testing the aux battery applies to the main battery too. Test it with a proper load tester. Don't rely on the terminal voltage.
Could your main battery be causing the stop/start fault? I honestly don't know. You would need to test it first. And/or poll the stop/start ECU and find out what it's whinging about. The stop/start ECU basically contains a computer, and that computer takes in a lot of information and makes decisions based on that information. What information it uses and what it does with it is up to the electrical engineers that designed the thing. It could "look" at the main battery, decide it's no good and refuse to start! That's completely on the cards.
But if you prove the main battery is Ok you can eliminate it as a cause.
frenchc3
hey guys,
I just put in a new battery, I thought I might as well do it to reduce one of the potential issues. But it hasn't changed a darn thing! grrrr, and again there's no pattern in the fault, I was able to start the car even with the message anti-lock fault.
But at least I was able to capture a video of what happens when the starter tries to start the engine. There's a first failed attempt and then a second successful attempt about 30 seconds later.
Any thoughts?
ozvtr
x 256
Sounded like there were two times the engine turned over and three times it failed to turn over. But each time I could hear the alternator/starter attempt to turn the engine over, but failed. Is that correct? In the text you only mentioned the two times the engine turned over.
I can tell when you have the ignition on because the throttle body squeals.
0:07-0:12 engine turns over but does not run.
0:24 and 0:34 attempt to start but fails to turn over.
0:45-1:00 long crank.
1:00-1:09 engine runs then shut down.
1:15 attempt to start but engine fails to turn over.
Seems to me you have more engine problems than starter problems.
The engine only ran once out of the two times it was turned over. And even then that was a very long crank!
Was the anti-theft warning being displayed?
I still think you need to look at that key.
Your car is a 2008 build. That makes it an "all CAN" electrics system. In a "REGULAR" car the starter wont run with an anti theft fault. BUT, I am not that familiar with the stop/start set up. But apparently the starter/alternator does run if there is an anti-theft fault. Well you live and learn.
I think that at the 1:00 mark of the video, the car was able to poll the key, and the engine ran. AND it started instantly. No coughing and spluttering or slowly building up steam. Typically, if there is an engine problem, the engine tends to chuff and puff and slowly begin to run. This guy started instantly!
frenchc3
ozvtr wrote: 19 Jun 2026, 00:54 Sounded like there were two times the engine turned over and three times it failed to turn over. But each time I could hear the alternator/starter attempt to turn the engine over, but failed. Is that correct? In the text you only mentioned the two times the engine turned over.
You described it correctly, the first attempt the engine turns over but does not run, the other attempts do not trigger the engine to turn over.
I believe the anti-theft was displayed when the engine was turning over.
I have to source a new key. What would be the engine problem?! The spark plugs are new.
When there's no hicup the engine starts instantly and usually runs smoothly. I am puzzled. It must be some stupid electronic thing.
Sloppysod
x 400
Unread post by Sloppysod »
frenchc3 wrote: 13 Jun 2026, 12:08 ......... would you have any clue what could be the relation with the "anti theft fault", "stat and stop fault", and that simply the starter will not attempt to start at all in certain cases
I had a C4, with a similar issue, sometimes I would get in the car, turn the ignition on nothing, but mine wouldn't even try the starter.
I identified my issue as, if unlocked, got in, key in ignition and turn too quickly it wouldn't turn over, let alone start. I would the have to lock the car, wait for the car to completely shutdown, 3-5 minutes, then unlock, and the car would start 1st time. It seemed the system starts slowly.
Never did find the actual reason , it was suggested a bad earth somewhere in the engine bay?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
ozvtr
x 256
frenchc3 wrote: 19 Jun 2026, 16:14 I have to source a new key. What would be the engine problem?! The spark plugs are new.
I'm sure it's the key. Sort that first.
frenchc3
ozvtr wrote: 19 Jun 2026, 21:07
Thanks, I have been looking to get a new key, unfortunately for now without any luck because the places I visited told me that if the key is corrupted and they try to copy it they might create a corrupted key.
I posed the problem in a French forum and one person suggested is the gearbox ECU, apparently there's only one place in the UK who rebuilds them https://www.ecutesting.com/common-fault ... arbox-ecu/ But I don't have any problem with the gear shifting or selection/
ozvtr
x 256
frenchc3 wrote: 21 Jun 2026, 23:35 the places I visited told me that if the key is corrupted and they try to copy it they might create a corrupted key.
I don't think the key is corrupt. I think that it's putting out a very weak signal.
frenchc3 wrote: 21 Jun 2026, 23:35 I posed the problem in a French forum and one person suggested is the gearbox ECU,
In a "regular" car, the Sensodrive can lock out the starter, if it's not happy. I guess that the same is true with the start/stop system. HOWEVER, if there were a fault with the sensodrive system (or any auto for that matter) the "*" and "S" symbols would flash on the instrument cluster. That tells the driver that there is a fault in the gearbox.
Unless the * and S pop up, the gearbox is not your problem.
