C4 1.6hdi esp and asr fault C1391 & U1208
gango67
x 3
Re: C4 1.6hdi esp and asr fault C1391 & U1208
Unread post by gango67 »
RichardW wrote: 14 May 2026, 11:15 Yes, the ABS faults are coms faults; when the engine ECU sets the fault code, it interrupts the data flow to the ABS ECU which causes the faults to be recorded there. Fix the injector (a common problem on DV6C engines) and the ABS light should clear. Note that injectors are numbered from the flywheel end.
Hi Richard would you happen to have the wiring diagram for injectors to Engine ECU at all as mine is playing up as I am trying to check continuity between pin 2 of each injector and engine ECU (48 pin ) or if anyone else has one many thanks
gango67
x 3
Does anyone have the wiring for the injection system on this car at all please
