Boxer proxy aligment
Jigzy
Re: Boxer proxy aligment
Unread post by Jigzy »
Hi yes its the airbag Ecu great the option of 5 I love this van thanks for the prompt reply to be fair and number should code to the van as would need to be lined up via proxy alignment and this could explain why on a global test
On diagbox i get this vehicle has multiple airbag ecu’s listed.
x 6945
No problem, sorry it's not as simple as I would of expected - this is almost a first...
I can only assume it's because of the endless possibilities of theses van formats, wheelbases and bodywork options as to why there are so many. Also, this has the Ford Puma Engine, so being a Ford variant may be another reason.
Let me know if you'd like the factory Build spec sheet.
Jigzy
Hi if you could send the factory build spec over that would be great, thanks for your assistance i’m further forward that I was this morning at least i have a part number or 4 lol I think I have narrowed it down as their is only one that is for 2011-2014 rest are for euro later models mind thats just using ebay as a quick guide it also looks like the connections hold different colours for different models I will
Not be beat thanks again i’ll be back next week no doubt!
Jigzy
Many thanks for the input managed to get the correct airbag comp using the codes so more digging on the instrument clusters required.
Many thanks
Lee
x 6945
Factory Build Sheet
Vehicle Characteristics
Vehicle familyBOXER 3
AS/RP N°13262
Warranty Start Date30/07/2013
Engine serial number10 TRJ5 0642149
BERe3*2007/46*0045*02
General Information
PRODUCT TYPECOMMERCIAL VEHICLE
COMMERCIAL MARQUE/COMPONENT TYPEPEUGEOT
VEHICLE FAMILYBOXER 3
SILHOUETTEVAN LONG WHEELBASE H2 TYPE 16H
TRIM LEVELSTANDARD
ENGINEDIESEL TURBO PUMA C 96 EURO5 130HP
TRANSMISSIONBVM6
PAINT TYPENON-METALLIC PAINT
BODY COLOUREWP - BANQUISE WHITE PAINT
INTERIOR TRIM TYPETRANSCODING CLOTH + EFKA "VM"
UPHOLSTERY COLOUR"FZ"
GEARBOX (CHARACTERISTICS)BVM6 MLGUC14
DEFINITION TO FOLLOWRANGE ACTIVITY
ENGINE (TYPE)ENGINE FORD
TRIM LEVELSTANDARD
STEERINGVARIABLE POWER STEERING
SPEEDOMETER DRIVETACHO TORQUE 18X14
Fuel supply-Engine
FUELDIESEL GRADE DA/DE/DE+
CAPACITY2200 CM3
VEHICLE EMISSIONS STANDARD (TYPE APPROVAL)EURO5 EMISSION CONTROL (APPROVAL)
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
TRANSMISSIONBVM6
FINAL DRIVE RATIOREAR AXLE HYPOID GEARSET 13 X 68
WHEEL (TYPE)STEEL WHEELS
INFLATION PRESSURE LOSS INDICATORWITHOUT TYRE DEFLATION INDICATOR
GEARBOX TYPEMLGU6 MANUAL GEARBOX
Suspension-Steering-Brakes
TRACTION CONTROLWITHOUT ANTISLIPPING
SUSPENSIONNORMAL SUSPENSION
SUSPENSION (ARCHITECTURE TYPE)FRONT SUSPENSION METAL REAR PNEUMATIC
DYNAMIC STABILITY CONTROL SYSTEMWITHOUT ELECTRONIC STABILITY PROGRAM
EMERGENCY BRAKING ASSISTANCEWITH EMERGENCY BRAKING ASSISTANCE
Body Fittings
AERIALLONG ROOF AERIAL
SKIPW/O FLAT HAMPER
CABINSINGLE OPENED CABIN
CHASSISSTANDARD CHASSIS
PAYLOADHEAVY PAYLOAD 16Q
SIDE MOULDINGS (TYPE)LATERAL PROTECTOR MASS TINTED
EXHAUST TAILPIPERIGHT-HAND SIDE
INDICATORSWITHOUT SIGNALING LIGHTS
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
EXT. REARVIEW MIRROR COMP. FUNCTIONEXT MIRROR MANUAL-FOLD BACK
OPENING OF MOVING PANELDOOR OPENING AT 180 DEGREES
WINDSCREEN WIPERFRONT WIPER BLADE W/O RAIN SENSOR
HEADLAMP WIPERW/O HEADLAMP WIPER
SIDE LOAD DOORLH SLIDING SIDE METAL DOOR
BUMPERDYED FRONT/REAR BUMPER
MUDFLAPWITHOUT MUDGUARD
ROOFSTANDARD ROOF PNL
LUGGAGE RACKWITHOUT ROOF BARS
FRONT FOGLAMPNO FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)PASSENGER ELECTRIC DOOR MIRROR
SPARE WHEEL MOUNTINGSTANDARD SPARE-WHEEL CARRIER
WHEEL EMBELLISHER (TYPE)WHEEL TRIM WITHOUT CUSTOMER CHOICE
BODY CONVERSIONWITHOUT
REAR WINDOW (TYPE)REAR GLASS HEATED
GLASS (APPEARANCE)TINTED
WINDOW (TYPE)LAM W/SCREEN + SIDE + RR TOUGHENED
SIDE WINDOW (COMM. VEH. ONLY)WITHOUT SIDE WINDOW
ROW 3 SIDE WINDOWWITHOUT SIDE WINDOW 3ND ROW
HANDS FREE ACCESS AND STARTINGNO ACCES AND HANDSFREE STARTING
Interior Fittings
ANTI-THEFT ALARMWITHOUT THEFT PROTECTION ALARM
REAR SEATWITHOUT REAR SEAT POSITION
SUPPLEMENTARY SEATWITHOUT SUPPLEMENTARY SEAT POSITN
CABIN SEAT1 PLACE PASSENGER SEAT
CIRCUIT BREAKERWITHOUT BATTERY CUT-OFF
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
SPEED GRADUATIONSSPEED GRADUATION IN MPH
DRIVING POSITIONRIGHT HAND DRIVE
REMOTE CONTROLREMOTE CONTROL ASSEMBLY
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
FRONT HEAD RESTRAINT (STYLE)OPEN FRONT HEAD RESTRAINT
TIMERWITHOUT TACHOGRAPH
RADIO CONTROLSREMOTE RADIO CONTROL
SIDE DOOR CONTROL MECHANISMNON-MOTORIZED, ELECTRIC LOCKING SIDE DOOR
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT REAR ADJUSTMENT SPACER
DRIVER SEAT CONTROLDRIVER SEAT MANUAL CONTROL
FRONT PASSENGER SEAT CONTROLPASSENGER FRT SEAT MANUAL CNTR
FRONT SEATWITH DRIVER’S SEAT
DRIVER SEAT ADJUSTMENTDRIVER’S LUMBAR ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENTPASSENGER LUMBAR ADJUSTMENT
FRONT SEAT ARMRESTDRIVER ANT PASSENGER FRONT ARMREST
STOWAGE BINWITHOUT SETTING BOX
SATELLITE NAVIGATION SYSTEMWITHOUT NAVIGATION SYSTEM
MISC. INT. ACCESSORYWITHOUT PORTABLE NAVIGATION MOUNTING
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGWITHOUT FRONT SIDE AIRBAG
PASSENGER AIRBAGNO PASSENGER AIRBAG
ADDITIONAL AIR CONDITIONINGWITHOUT ADDITIONAL AIR CONDITIONING
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED DOOR MIRROR
REAR MOVING PANEL2 REAR HINGED WINDOW DOORS
COURTESY LAMPFR+RE DOORS CONT - FR+RE INTERIOR LAMP
FRONT SEAT GUARDCAB PROTECTION LADDER
RADIO RECEIVERDIGITAL RADIO CD+MP3 REMOTE DISPLAY
REFRIGERATIONSINGLE AIR CONDITIONING
CRUISE CONTROLWITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROLFR + RR DRIVER HEIGHT ADJ
REAR VIEW MIRRORSSTANDARD REAR VISION
DRIVER AIRBAGDRIVERS AIR BAG
OBSTACLE DETECTION SYSTEMWITHOUT OBSTACLE DETECTOR
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
PASSENGER SEAT PACKHEIGHT ADJ SEAT + ARMREST
SUPPLEMENTARY HEATERWITHOUT ADDITIONAL HEATING
AUDIO PACK AUXILIARY SOCKET1 USB SOCKET
Electrical
BATTERY (FITTING)UPPER BATTERY
Component Manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
RADIO HEADPHONE SOCKETWITHOUT ACCESSORIES SOCKET
PLATEWITHOUT PLATFORM FLOOR
SET OF KEYS1 HIGH FREQUENCY REMOTE CONTROL KEY+1 MAIN KEY ONLY
COUNTRY ADAPTATIONWITHOUT
EMERGENCY EQUIPMENTW/O HELP EQUIPMENT
SURFACE CONDITIONSGOOD TERRAIN
