I’ll move up to a higher class where I can relocate the radiator to the back of the car. I’ll install the one from the Xsara, which is significantly larger. I also believe that the longer water hoses, which will hold a lot of water themselves, might help reduce heat soaking.
I’ll start by running it without a thermostat since I expect the water will slow down quite a bit in the longer hoses. If that doesn’t solve the issue, I’ll try partially blocking off the thermostat housing.
I just hope the waterpump can keep up..
Thanks again for all your input. I’ll keep you updated on the project.
