Servicing is Annually or every 12,500 miles - whichever comes first.
Timing belt is part of a Wet Belt system - so essential to have it regularly checked at least yearly as part of the service and that correct grade of oil is used to help reduce deterioration of the belt.
Timing belt must be changed at 62.5k miles or 6 years whichever is soonest, then every 125k miles or 12 years (but I seriously would not leave it that long given the issues with this system!).
Oil Grade: 5W30
Spec: FPW9.55535/03
Ancillary drive belt is the same for the timing belt.
Brake fluid must be changed every 2 years
Coolant every 112k miles or 10 years
Check of PH level of coolant every 75k miles / 4 years, then every 12.5k miles / yearly
Air filter & Spark Plugs every 25k miles or 4 years
2020 C5 Aircross Automatic 1.2L PureTech
- x 6945
Re: 2020 C5 Aircross Automatic 1.2L PureTech
