C5 X7 Wiring Diagram
- x 1939
Re: C5 X7 Wiring Diagram
How old is the car battery?
PaulC5
- x 696
In a post it says it was replaced with a new one, however, it still needs the voltage checking as something might be draining it causing it to go flat.
Vule
Here are the links:Paul-R wrote: 07 May 2026, 08:37Not directly. Post your video on YouTube and then post a link to that video here. Make sure the video is set to be visible to everyone on YouTube.Vule wrote: 07 May 2026, 08:24Is it possible to upload videos? I have two recordings that I took and can show the situation on the car
Vule
The one I have on the car is 3 months old
- x 1463
When viewing the live diagnostic data do the various relays controlling engine starting appear to be in the correct state? The clicking from the BSM seems to indicate that one of them will be in the wrong state.
Vule
thanks for the advice, I'll send the information to the service center and see what they sayxantia_v6 wrote: 07 May 2026, 14:40 When viewing the live diagnostic data do the various relays controlling engine starting appear to be in the correct state? The clicking from the BSM seems to indicate that one of them will be in the wrong state.
- x 1463
My guess (given that the BSM has already been replaced) is that the fault is in the BSI, either a bad solder connection or a faulty relay.
Vule
I got a new ECU last week. The new ECU is starting the connection of the car and now they are working on to get the PIN code. I hope it will be resolved soon
Vule
Just to thank all for help.
The car was repaired. The ECU was the problem.
My computer broke and I change my workplace and didn't have time to thank you all!
